Electrical
Truck wont start!
Topic: Truck wont start! (Read 9514 times)
82oldskid
Truck wont start!
April 23, 2014, 10:18:20 pm »
I know this ain't about a 73-87 truck, but I was hoping somebody might be able to help. I recently put a starter in an 01 Silverado with a 5.3. Before this, the truck wouldn't crank at all. Put the new starter in and now it cranks but won't fire. This wasn't an issue before the starter died. Now it just cranks like its not getting fuel or spark. I haven't gotten into diagnosing anything yet, bit I know the fuel pump is cranking. I'm kinda baffled and am looking for any ideas on this. If anyone has any ideas on this, please chime in. Thanks!
Re: Truck wont start!
April 24, 2014, 12:39:44 am »
make sure you're getting spark and signal to the injectors
bake74
April 24, 2014, 07:29:39 am »
Quote from: Irish_Alley on April 24, 2014, 12:39:44 am
Did you see if there was any codes that would pull ?
74 k10, 77k10 Tom
82oldskid
April 24, 2014, 07:47:16 am »
Irish_Alley: Thats the game plan for tonight. And I'm checking the fuel pressure, even though the pump is running. The guy who brought this truck to me didn't even know what year the truck was, or what motor, so for all I know, this could have been a long time problem that he never noticed.
bake74: Haven't yet, my buddy is bringing his code reader tonight for me. I'm a little skeptical cause the battery was disconnected, but then again, it did save the radio settings when I hooked it back up, so who knows.
Unfortunetly, I'm at my day job right now, so I can't do anything til this evening, but in the mean time, keep the suggestions rolling! Thanks for your answers so far!
bake74
April 24, 2014, 08:30:12 am »
Well if it does not show any codes that is a bummer. I am sure before you get home tonight more members will chime in.
74 k10, 77k10 Tom
thirsty
April 24, 2014, 06:01:32 pm »
When you are digging into this remember the basics that every motor needs to run.
Air, Fuel, and Spark at the right time.
Build thread
April 24, 2014, 10:42:59 pm »
even with good fuel pressure this doesnt mean the injectors are getting signal to fire. dont know if its the only way but i have a diode tester set and thats how i check for signal
74bluebowtie
April 25, 2014, 08:08:26 am »
Could be a Passlock issue. Google how to let the BCM relearn the key. And there is a way to solder a resistor into the circuit to bypass it permanently.
When this happens the vehicle will usually crank but it shuts down the injectors.
82oldskid
April 28, 2014, 09:28:29 am »
sorry I haven't updated in a few days, was a long weekend. Working on this and doin a clutch in a mustang at the same time, then took my woman to the hospital after she tripped and hurt her knee pretty good. What a lovely weekend... anyhoo, plugged in a scanner, got code P0335 - No signal from the Crank Sensor. Checked power to the sensor, all good. Checked all the fuses, good there. Swapped the Crank Sensor, still no start, and getting the same code. so, tonights game plan, picking up a set of noid lights, gonna check the injector pulses, and gonna check for spark. This job reminds me how much I love my two 86 Chevy's, cause when something like this happens, it's a heck of alot easier to diagnose!
Either way, thanks for the responses so far. keep em comin!
bd
April 28, 2014, 03:48:25 pm »
Check and clean all the harness connections to the PCM. Ohm out the PCM-to-CKP sensor wire. Verify all the PCM grounds.
Read through
PO335 - Crankshaft Position Sensor A Circuit Malfunction
82oldskid
May 06, 2014, 04:26:41 pm »
well, just figured I'd update on this. after having someone come by with an actual good scanner, and going through the process of elimination, everything seems to be pointing to either the ECM or BCM. We read some other codes that my cheap-o scanner couldn't, and apparently sometime in the past, there was a loss of power to the BCM. Sucks, but at least I know I didn't screw anything up, as this was a prior issue. So, yea, thats where we're at. Just didn't wanna be one of theose guys who doesn't ever post what the final result was. haha
Thanks to everyone for your assistance even so, I greatly appreciate it!
May 06, 2014, 10:57:17 pm »
good luck with it
Electrical
Truck wont start!
