Author Topic: 14 bolt rear  (Read 12580 times)
Offline 87V20Kansan
14 bolt rear
« on: April 24, 2014, 12:00:49 am »
Will the 14 bolt FF out of the '88-'98 trucks fit under our trucks? They sure are a lot more plentiful at the pick and pull around my part of the world.  I know that the mounting pads for the springs are in different locations and pinion snout length differences may alter my driveshaft length. I can handle all of that with no issue. Is the axle flange to flange width even close? I can never find a 73-87 14 bolt FF in a yard to even measure. I sure would like to make that work rather than buying and gutting a 1-ton squarebody. Keep in mind that I m running the H1 wheel with a 2 inch spacer already. I can grow the flange widths up to about 4-1/2" inches from the K20's 9.5 inch 14 bolt and lose the spacer if I need to.
Cecil: 1987 V20, TBI 350, TH400, 4:10's, 7" lift, 37" H1 beadlocked runflats. Cummins swap someday.
Offline Da67goatman
  • Burban
Re: 14 bolt rear
« Reply #1 on: April 24, 2014, 03:42:28 am »
Spring perches are farther apart on 88-98.
<Pitcrew>
Offline Engineer
Re: 14 bolt rear
« Reply #2 on: April 24, 2014, 08:08:34 pm »
Wow, I have been looking for a 14-bolt FF for my '94 K2500 and can't find one anywhere. The 73-87 14-bolts are all over the place around here. And never more than 2-3 phone calls away.......
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Offline 87V20Kansan
Re: 14 bolt rear
« Reply #3 on: April 25, 2014, 12:05:42 am »
Maybe we can make something happen Engineer. I have them show up 8 out of 10 times I happen to go to the yards around here. I'd love to have a direct swap into my truck  with 4:10 gears.
Offline pholliday1
  • 1990 V3500 Crew Cab
Re: 14 bolt rear
« Reply #4 on: April 26, 2014, 09:29:37 am »
You mentioned" pinion snout lenght" pretty sure that's a nonissue as I believe there all the same
Offline 87V20Kansan
Re: 14 bolt rear
« Reply #5 on: April 28, 2014, 09:05:11 am »
Really? Interesting. I would have assumed there would be a difference in the 10.5 vs. the 9.5 inch rear ends. So in a swap from 3/4 ton to the square body 1 ton FF, you don't have to alter driveshaft length?
Offline timthescarrd
Re: 14 bolt rear
« Reply #6 on: April 28, 2014, 12:01:23 pm »
The 9.5" Semi-Float rear and 10.5" Full-Float rear have different pinion snout length.  But th3 73-87 14 Bolt FF and the 88-98 14 Bolt FF are the same.  So if the 3/4ton came with a semi-float 14 bolt, the drive shaft may need shortened when changing to a 1ton full-float.
Some K20's came with the 14 bolt FF
Offline 87V20Kansan
Re: 14 bolt rear
« Reply #7 on: April 28, 2014, 08:18:50 pm »
That sounds exactly as I hoped it would. Now why didn't I get lucky enough to buy a K20 with  a 14FF?  ;)
So are the track widths the same from the 2 different generations? That is the real question at hand. Will the wheel and tire package get shoved way outside of the body line with a later model rear?
Offline pholliday1
Re: 14 bolt rear
« Reply #8 on: April 28, 2014, 09:05:15 pm »
Thanks timthecard that's what I meant
