Author Topic: Turn signals out but Hazards still work?  (Read 6933 times)
Offline jpatters13
    • 74' Chevy Truck Project
« on: April 29, 2014, 07:33:59 pm »
So my blinkers stopped working. When I try to use them it cancels the brake light on whatever side I am trying to get to work but it doesn't blink. The fuse is still good and the hazards still work so it can't be the relay can it?  I changed out the blinker module under the steering wheel hoping it had a short or something but still no turn signals. Any clue?
84 Silverado K10
74 Custom Deluxe C10
Re: Turn signals out but Hazards still work?
« Reply #1 on: April 29, 2014, 07:53:41 pm »
What year and model vehicle?
Assuming that you verified the bulbs aren't burned out and that they are making good connection in the sockets, there are two flashers - turn and hazard.  Swap the flashers to see what happens.  You may have a weak turn flasher.
Offline jpatters13
« Reply #2 on: April 29, 2014, 08:26:10 pm »
Its an 84 Silverado k10 with a 305. I only see one flasher that is marked turn signal and hazard
84 Silverado K10
Offline jpatters13
« Reply #3 on: April 29, 2014, 08:57:54 pm »
Okay, I feel like and idiot but problem solved. I thought the turn signal flasher and the hazard flasher were the same one. I popped out the hazard flasher from the top of the fuse block and popped it into the turn signal spot and they work.  Thanks for the answer...
84 Silverado K10
« Reply #4 on: April 29, 2014, 09:01:01 pm »
You're welcome.   ;)
