Author Topic: Engine Swap  (Read 2677 times)
Offline james.hamblin.161
Engine Swap
« on: May 05, 2014, 01:54:47 pm »
 Ive got 1983 Chevy C-10, with an inline 6, 250. With almost 250k miles, the headgasket finally blew. Im wanting to drop in an older 350 I have laying around the house. As far as wiring and such, what needs to be changed, if anything? I know the engine mounts and radiator will need to be changed, but am I missing anything?
 Its just an old work truck,that I drive 60 miles a day,  but as much as I have read, I will even get better gas mileage out of the 350 than the I-6.
Re: Engine Swap
« Reply #1 on: May 05, 2014, 06:26:36 pm »
If it is a mild 350 or stock it can probably get away with using the stock radiator for now.  The frame mounts on the crossmember have to be moved from the 6 position to the 8 position.  the mounts on the engine will need to be obtained.  If it is just a simple carb setup you should be able to note where the current wiring got on the 6 and make it work on the 8.
