Author Topic: New Dip Stick Tube  (Read 16122 times)
Offline LTZ C20
New Dip Stick Tube
« on: May 06, 2014, 02:20:06 pm »
Hey all. Thought I would share this small side project I did last night.
I put new headers on my truck and in doing so I had to remove my dipstick tube. In doing that I bent and put a small hole in the tube. So I decided to build a new one using my old stock dipstick tube.
I have a chrome stick and tube from Mr. Gasket, nothing special. Turns out the metal the tube is made out of is not that great.
Here is both sticks and tubes.
« Last Edit: May 06, 2014, 02:38:15 pm by LTZ C20 »
LTZ Cheyenne C20
Offline LTZ C20
New Dip Stick Tube
« Reply #1 on: May 06, 2014, 02:24:37 pm »
Now here is the chrome tube damaged.
You can see here, I measured to two tubes, making sure they had the same arc, then using a tubing cutter, cut the stock tube to the same length as the chrome.
The two stick handles.
« Last Edit: May 06, 2014, 02:39:09 pm by LTZ C20 »
LTZ Cheyenne C20
Offline LTZ C20
New Dip Stick Tube
« Reply #2 on: May 06, 2014, 02:45:03 pm »
I'm sorry the pics are out of order, I'm still learning how to post pics from my phone lol.
So then I primered the tube with engine enamel.
Then painted with low gloss black engine enamel.
Finally, I tried to stamp with a steel punch set, "SAE ROYAL PURPLE ONLY" into the opposite side of the dipstick. It didn't work, so I used an engraver instead. Doesn't look as good as I hoped but it's ok. That was kind of a stupid idea anyway. Haha.
« Last Edit: May 06, 2014, 02:47:30 pm by LTZ C20 »
LTZ Cheyenne C20
Offline LTZ C20
Re: New Dip Stick Tube
« Reply #3 on: May 06, 2014, 02:48:34 pm »
Will post the final installed pic tonight when done.
LTZ Cheyenne C20
« Reply #4 on: May 06, 2014, 09:21:21 pm »
      Engravers are hard to keep steady, it takes patience and practice.  Both of which I have not mastered yet.   ;D
Offline LTZ C20
« Reply #5 on: May 06, 2014, 10:00:29 pm »
Lol me either. Here's the final product.
LTZ Cheyenne C20
Offline LTZ C20
« Reply #6 on: May 06, 2014, 10:01:28 pm »
Installed.
LTZ Cheyenne C20
« Reply #7 on: May 07, 2014, 09:28:55 am »
     Did you paint over the etching ?
Offline LTZ C20
« Reply #8 on: May 07, 2014, 01:48:16 pm »
No I did not. I etched into the dipstick itself, which was chrome
LTZ Cheyenne C20
« Reply #9 on: May 07, 2014, 07:50:22 pm »
     Couldn't tell from the pic, but that makes since.
Offline LTZ C20
« Reply #10 on: May 07, 2014, 08:20:01 pm »
Oh ok. Yea. I had the etcher on about medium cuz high felt like it was gonna grind a hole thru my workbench.
LTZ Cheyenne C20
