Author Topic: Manual to Auto swap?  (Read 34538 times)
Offline mizozuman2
  • Something goes here... but what?
« on: May 12, 2014, 12:17:21 am »
Hey everyone.
Here in a week or so, I'll be purchasing a truck. It's an '84 C10 SWB with a 350/4 speed. I have seen a lot of Automatic to manual swaps, and have seen that you have to change the trans hump in them. But what do you have to do with a Manual to Auto trans swap?
Driveshaft, flexplate, converter, trans, yoke? It'd be a TH350, or a TH400.
Yes, I can drive a manual transmission. But I am wanting to have an auto.
Please don't tell me "Just find an auto transmission truck and buy it instead". This is what I'm wanting to do, because the truck is in actual good shape for the price he wants.
Thanks for any help and advice!
1986 Chevrolet C10 "Heavy Half"
350 4bbl
Long bed/Reg Cab
Re: Manual to Auto swap?
« Reply #1 on: May 12, 2014, 07:25:14 am »
     You got the basics down, you will not have the stalk on the steering column for and automatic.  So just put a floor shifter in and you will be set.  Otherwise you will have to change out the steering column and run the rods for the auto tranny shifter.
     If it was me, I would go with the floor shifter, I like the looks of those.
Offline Gusgusa1
  • Gasket
« Reply #2 on: May 12, 2014, 02:23:08 pm »
I was think of this on my 84. Please update thread with build info. Hard to find info on this. Thanks.
2002 gmc 1500hd 6.0 4x4
1987 gmc Sierra classic 1500 350ss 4x4
1986 silverado 350 4x4
1984 scottsdale 305 quad jet 4x4 4spd manual
1982 camaro z28 350 w vortec heads spool
Offline mizozuman2
« Reply #3 on: May 12, 2014, 03:31:12 pm »
So something like a B&M Ratchet Shifter? Or are there other ones? I like how the Ratchet Shifters work, but i don't know how big their truck series ones are (Height wise), and I don't care to reach 2 feet while driving to shift it. Though "Drive" is the trans shifting, correct?
350 4bbl
Long bed/Reg Cab
Offline mizozuman2
« Reply #4 on: May 12, 2014, 03:34:43 pm »
I'll try to keep it updated as much as possible!
350 4bbl
Long bed/Reg Cab
« Reply #5 on: May 12, 2014, 05:52:41 pm »
I did this swap on a 79 C10.  It was so easy for me cause I went from a 3 speed manual and I had a parts truck.  The only thing I had to do was get a flex plate for the 250 engine and the kick down cable bracket for the transmission.  I just bolted the 2 shift levers together and used one of the levers to shift the transmission.  The previous owner had converted it to a floor shift.  The 3 speed manual had a 2 piece drive shaft and the TH350 truck had a one piece so I used that.  The exhaust pipe hit the one piece drive shaft so a slight bend was needed to get it to clear.  I left the clutch pedal in it for the neutral safety switch.  The radiator needed changed because mine didn't have the trans cooler in it.  Made up some cooler lines and off she went.  This had to be about 15 years ago and I didn't have the money for a new clutch when it went out so this was the best option at the time.  It was a beater truck and the automatic actually made it nicer
Offline mizozuman2
« Reply #6 on: May 13, 2014, 03:29:18 pm »
So did you have to change the Transmission hump in the truck?
350 4bbl
Long bed/Reg Cab
« Reply #7 on: May 13, 2014, 04:09:20 pm »
No the only time you would have to change a transmission hump would be to go to a SM465 from an automatic.  The automatic is fine in any hump configuration.
Offline mizozuman2
« Reply #8 on: May 13, 2014, 04:21:41 pm »
Oh tank goodness. That was a big worry of mine. I can't weld for nothing! Haha And I don't want to pay a shop for it either.
350 4bbl
Long bed/Reg Cab
« Reply #9 on: May 13, 2014, 05:01:25 pm »
With the extra room between the transmission and trans tunnel your down force will be less but probably won't notice it under 100...
Offline mizozuman2
« Reply #10 on: May 13, 2014, 05:47:57 pm »
Good thing I don't need it to go faster than 75-80. LOL
350 4bbl
Long bed/Reg Cab
Offline roundhouse
« Reply #11 on: May 14, 2014, 11:12:29 am »
Find a donor truck. Grab the parts you need
Might be able to swap in a tilt wheel while you're at it
What trans does yours have the SM 465. With granny first  ?
Offline mizozuman2
« Reply #12 on: May 14, 2014, 01:02:37 pm »
Yeah, it's an SM 465.
and there's no trucks for a good price down here to make a donor truck. the problem is finding a SWB for cheap with the parts needed. Everything here is either a $20K restored truck, or a $500 long bed. That's why I snatched up this deal as soon as I saw it.
Does anywhere sell driveshafts? and which auto trans would be best to go with? I'm wanting to get a 383 stroker to 450 horses or so.
350 4bbl
Long bed/Reg Cab
Offline roundhouse
« Reply #13 on: May 16, 2014, 11:57:32 am »
You can't use parts from a LWB donor?
I wojldnt want the whole truck but is would work pit better If you can grab all the parts from the same donor truck
Don't know about the trans.  A good built TH should be fine and you may be able to use a 4L60
I doubt the Normal AOD is strong enough
We used to have a 30 passenger bus with a 454 and I think it was a L60 trans
Offline mizozuman2
« Reply #14 on: May 16, 2014, 04:05:30 pm »
I have to have a different Driveshaft for the swap. the LWB wouldn't have the correct driveshaft if I remember right. everything else would be able to be swapped, but not the driveshaft. which is the thing I need the most. I know the guy the owns the junk yard here, and I'm sure he'd cut me a deal on an engine and trans. But he has no SWB autos.
350 4bbl
Long bed/Reg Cab
