Author Topic: 1986 Clutch switch pigtail/plug. I NEED ONE!  (Read 5098 times)
Offline kirby1374
« on: May 12, 2014, 11:36:22 pm »
Hey all. I am swapping my th400 for a sm465 in my 1985 K30 Crew Cab. I am installing a hydraulic clutch pedal assembly and want to make this look as much like a factory install as I can. With that said, I am wanting to us the clutch switch for the neutral safety and cruise interrupt. I have the switch, I know where it goes, what it does, etc. But for the life of me I cannot find the special plugs/pigtails to plug into this switch. HELP
Re: 1986 Clutch switch pigtail/plug. I NEED ONE!
« Reply #1 on: May 13, 2014, 08:11:35 am »
     The AC Delco website for GM Pigtails is down right this second, but check back here when you can, they probably will have it.
http://www.acdelcotechconnect.com/parts-catalog/wiring-sockets-pigtails/
Offline kirby1374
« Reply #2 on: May 13, 2014, 12:11:42 pm »
Thanks, I will try that site later. I spent several hours searching the Web yesterday to no avail.
« Reply #3 on: May 13, 2014, 02:58:13 pm »
That other address maybe inaccessible for awhile.  Try this - 2013 Delco Pigtail Guide
Offline kirby1374
« Reply #4 on: May 13, 2014, 04:30:33 pm »
My local dealership says that that connector has been discontinued. I guess it's to the wrecking yard I go. Unless you all have a better solution.
Offline kirby1374
« Reply #5 on: May 14, 2014, 02:51:57 pm »
No worries, I made my own. I had a female side of a steering column connector that I cut down. :)
Sent from my XT901 using Tapatalk
