Body, Glass & Paint
cab swap question
Topic: cab swap question (Read 4102 times)
2tone4by
cab swap question
May 13, 2014, 08:55:22 pm »
will a 2 wheel drive cab work on a 4 wheel drive truck. any mods have to be done?
Re: cab swap question
May 13, 2014, 08:57:17 pm »
Yes it will work. You will need to either cut the bolt in tunnel out (or the high tunnel out if it isn't bolt in) or put a body lift on to clear the drivetrain.
Dan75k20
May 15, 2014, 04:23:22 pm »
Capt won't the bolt in tunnel out of a 4wd work for his application ?
May 25, 2014, 01:40:58 pm »
Yes, but you still have to cut it so the bolt in will work..
Engineer
May 29, 2014, 10:10:40 pm »
All 4x4 cabs, and some C30 cabs I have seen also have a raised center section aft of the bolt in hump that has to be welded in to a standard 4x2 cab to clear the transfer case....... Not an issue if you use a body lift.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Body, Glass & Paint
cab swap question
