Author Topic: Difference between Brake Calipers 4x4 vs 2WD  (Read 4340 times)
Offline jason
« on: May 15, 2014, 01:40:35 pm »
So.. I'm about to do a rear disc brake conversion on a 14 bolt 3/4 TON AXLE that's going into my truck.
Apparently, a 14 bolt rear axle swap requires CALIPERS from a 3/4 ton 4X4 truck.  The calipers HAVE to be from a 4x4 truck.
I have access to a 2WD 3/4 ton truck.
What is the difference, if any, between a 3/4 ton 4x4 front caliper and a 2WD front caliper? Are they identical?
Thanks for the feedback!!!
Re: Difference between Brake Calipers 4x4 vs 2WD
« Reply #1 on: May 15, 2014, 11:26:26 pm »
what truck?
