Author Topic: 1990 GMC V2500 purchase  (Read 5899 times)
Offline TennesseeBoy
« on: May 16, 2014, 08:59:21 am »
Hey guys, Ive been a lurker on this forum forever, but not a member until a few days ago.  You guys know a TON of good stuff.
I want to buy a 1990 GMC 2500 4x4 Suburban from a friend. Ive never had a SAS Chevy, always had IFS, and i have a couple suspension questions.
Its had a 6" lift on it for about 10 years with no problems. He did springs in the front, and 4" blocks and AAL in the rear.
First, what can I look at to see if it was installed properly and the front isn't gonna give me a ton of problems?  Second, it rides like crap.  I know its a 2500 4x4, but can i get better shocks, delete the lift blocks and replace with leafs and make it better?
Thanks!
Re: 1990 GMC V2500 purchase
« Reply #1 on: May 16, 2014, 10:55:18 pm »
the lift block will generally give it a better ride than spring. just because the two mounting points stay the same so you have more of a arch in the springs. but you will also notice different spring manufacturers have different quality in a ride. i have rough country and other will tell you the same they ride rough. skyjacker makes a good spring (softride) but you will pay for it
« Reply #2 on: May 18, 2014, 10:12:30 am »
     Welcome TennesseeBoy.  As far as the front goes, do a check of all the suspension parts.  Do this with the vehicle on level ground, look under the front of vehicle and have your friend turn the steering wheel back and forth and you check for any loose parts.  This will give you a idea of how worn the front is and if you will need to replace anything.  Also take it for a test drive next to see if anything feels loose.
     As far as it riding like "crap", what do you mean exactly ?  It wonders all over the road ?  It bounces you to death ?  It wonders and bounces you all over the road ?
     The better you can tell us what you feel, see, hear, it will only help us on letting you know our thoughts.  Good luck.
