Author Topic: Cigarette lighter and dome light connected?  (Read 5038 times)
Offline Sprinkler-Man
  • 80 GMC Sierra Classic 4x4
« on: May 18, 2014, 09:11:28 pm »
I just put in a after market cigarette lighter and when I plugged it in I heard a pop and now the lighter or dome lights don't work.  I checked all the fuses and none appeared to be blown.  Any ideas?
Re: Cigarette lighter and dome light connected?
« Reply #1 on: May 18, 2014, 09:21:55 pm »
Replace the blown horn fuse.
« Reply #2 on: May 19, 2014, 06:46:42 pm »
I will give that a try.  The aftermarket lighter came with a metal threaded shaft in the center of the rear of the lighter and a tab on the outer case.  The original lighter only had the the tab but it went to the center of the lighter.  When I attached the hot lead to the tab on the outer case this is when it blew.  Is this some sort of ground spot?
« Reply #3 on: May 19, 2014, 07:17:57 pm »
The outer tab is the ground connection.  The center post is the hot connection.  By plugging up to the tab you grounded the battery wire and popped a fuse.  Look at it this way, now you know that fuses work.   ;)
« Reply #4 on: May 19, 2014, 07:18:16 pm »
     A picture would be nice, but if I read that right, the outside casing for the cigarette lighter should be were it is grounded.  What brand of cigarette lighter did you buy ?  Rich beat me to it.
« Reply #5 on: June 01, 2014, 08:25:45 pm »
Not sure what brand but it was an aftermarket.  I modified a connector to hook up the lighter to the truck wiring and everything seems to be working fine.  The horn fuse was blown.  I missed it the first time.
« Last Edit: June 02, 2014, 12:37:38 am by bd »
« Reply #6 on: June 02, 2014, 10:33:49 am »
     Glad to hear you got it fixed.
