Author Topic: how hard would it be to adapt an 84 harness into an 81 c10 ???  (Read 3553 times)
Offline Dan75k20
Thinking about buying an 81 c10 2wd long bed not in top bad of shape some of the wires under the dash fried I can get this truck dirt cheap and its not in all that bad of shape  have a wiring harness out of an 84 i am wondering if,its worth my time to adapt the 84 wiring harness,to the 81 or buy a wiring harness
Re: how hard would it be to adapt an 84 harness into an 81 c10 ???
« Reply #1 on: May 19, 2014, 07:23:24 pm »
     73 - 82 is the kit that this site sells, so the 84 will have to be modified.  How much it will have to be modified I can not tell you, it depends I guess on what items were different on the 2 trucks, could be minimal or a lot.
     I also assume the connectors on a lot of the ends are different.
« Reply #2 on: May 19, 2014, 07:53:39 pm »
One difference that I know of is the turn signal stalk on the 84 holds the wiper and dimmer switch.  I put a 84 column in a 1982 and it wasn't that big of deal to get it to work off the column
Offline Dan75k20
« Reply #3 on: May 20, 2014, 10:56:40 am »
I figured it wouldn't be too bad for 600 bucks inspected till 1-15 and the body isn't too bad either
