Author Topic: Bench seat bolt sizes?  (Read 46868 times)
Offline mizozuman2
  • Something goes here... but what?
« on: May 21, 2014, 10:48:02 pm »
What are the bolt sizes that connect the bench seat to the floor of the cab?
Size, thread pitch, Length?
Thanks!
1986 Chevrolet C10 "Heavy Half"
350 4bbl
Long bed/Reg Cab
Offline rich weyand
Re: Bench seat bolt sizes?
« Reply #1 on: May 22, 2014, 12:32:48 am »
Parts book says 3/8"-16 x 1-1/4", which jives with my memory from replacing them a couple years back.  Note: I believe they are grade 5 or 8; I used grade 8 bolts to replace them.  DO NOT USE LONGER BOLTS OR YOU CAN PENETRATE THE GAS TANK.  I also used a 3/8"-16 tap to clean up the threads in the hard points in the floor before I put in the new bolts.  Again, do not go deep enough with the tap to contact the fuel tank(s).  I had a problem where some of the bolts had threads worn enough that they would not pull up tight.  New bolts solved that.
Note: you did not mention the model year (I don't remember from the other thread we are chatting in).  This info is from the 1973-1978 parts book.
Offline mizozuman2
« Reply #2 on: May 22, 2014, 03:04:56 am »
I just need to make the truck my signature... LOL
Thanks. I'll check around some more. a guy gave me a link for an '86 Service manual. That should help me out quite a bit. Now, to find a printer..........
350 4bbl
Long bed/Reg Cab
Offline rich weyand
« Reply #3 on: May 22, 2014, 03:29:25 am »
That bolt probably did not change unless the seat belt mounts migrated to the seats.  You can always pull one out and check it.  If you pull one, pull out one of the front ones.
« Reply #4 on: May 22, 2014, 05:34:09 am »
I can confirm that the bolts throughout the 73-87(91) is all the same
Offline mizozuman2
« Reply #5 on: May 22, 2014, 06:50:41 am »
Awesome! Thanks!
350 4bbl
Long bed/Reg Cab
Offline 87 ChevyVan
« Reply #6 on: October 04, 2020, 09:01:21 pm »
Pretty funny.
I was trying to take the bench seat out of my 87 G20 Van, and did not have the right size deep well socket.  Seems that it is a 3/8 bolt with a 9/16 head.  9/16 deep well is the only size I did not have.
