Author Topic: Need Help For The Rear  (Read 11994 times)
Offline bad86c10
« on: May 24, 2014, 06:26:54 pm »
This is why i need help....i wanna keep it like the same length and a regular rear. The only reason why i need it is so i can build a street truck.
http://www.ecklerstrucks.com/chevy-gmc-truck-rear-end-9-complete-with-wilwood-disc-brakes-and-lines-1973-1987.html
Thanks for the help.
« Last Edit: May 24, 2014, 06:28:40 pm by bad86c10 »
Re: Need Help For The Rear
« Reply #1 on: May 24, 2014, 09:23:51 pm »
First, Welcome to the site!
Second, we're not clairvoyant.  If you want help you have to tell us what you're working on.  And, then actually pose a question or problem with which you want the help.
« Reply #2 on: May 24, 2014, 11:44:30 pm »
     X2 on above.  I guess you have a 86 C10 by your signature.  And let me play, you want to take your axle and turn it into what is in the link and you want us to help you ?  Or asking if this axle will work in your truck ?
Offline bad86c10
« Reply #3 on: May 26, 2014, 10:11:28 am »
well in trying to find out the drum to drum width and the spring perch center to center width so i can build the street truck
Offline BADAZ chevy guy
  • Chevy! My drug of choice!
« Reply #4 on: May 26, 2014, 11:05:56 am »
Can we assume you don't have the OEM rear end to measure?
Do you still have the springs mounted on the frame? If so you can measure them C to C (center to center) That should be the same as your spring perch C to C. Once you have that, the distance between backing plates doesn't have to be the same as stock. (Within an inch or so) This could be a good time to figure out what wheel and tire combo you want and build the rear end to match.
Offline bad86c10
« Reply #5 on: May 27, 2014, 09:48:41 am »
No I don't have the OEM rear. but i got something better than my shortbed .....I've picked up a 86 GMC Sierra longbed. I recently put a TH400 in it but i need to get a longer driveshaft. I'm gonna run 15x12 in the back and 15x6 in the front. but now some of my friends say i should lower it. witch direction should i go now?
« Reply #6 on: May 27, 2014, 10:41:49 am »
     So just to clarify, you are looking for the width of the overall axle and spring perch location center to center correct ?
     Just a question, did you pick up the 86 without a rear axle ?  Otherwise it should have the stock axle in it.
     More information please.
Offline bad86c10
« Reply #7 on: May 27, 2014, 06:26:50 pm »
Yes bake74 thats what im looking for. and it didn't come with a rear axle.
« Reply #8 on: May 28, 2014, 08:35:59 pm »
     OK, so now I understand.  I do not know if you knew about the GM Heritage website that we have a link for in our tech section, but here is the address.   http://www.gmheritagecenter.com/gm-heritage-archive/vehicle-information-kits.html
     Unfortunately I did not see the actual measurements you are looking for, but they have about everything else.  I am going to pm somebody on here that has a 85 and ask him to look at this thread, maybe he can measure his for you or just know what his is .
« Reply #9 on: May 28, 2014, 08:49:12 pm »
I have a stock 10 bolt 2 wheel drive rear end from a 1986C10 I will measure for you.  It won't be until Saturday sometime.  I travel for my job now and am only home on the weekends
Offline bad86c10
« Reply #10 on: May 29, 2014, 07:16:36 am »
thanks zieg85. I don't mind to wait
