Author Topic: 84 K30 Rear Proportion Valve Photos needed  (Read 7867 times)
Offline srodster
« on: May 25, 2014, 12:55:07 pm »
Anyone have some photos of their rear axle with the height leveling proportion valve?  I have seen the photos from the manual, but would like some up close photos of the linkage to the valve, and the bracket from anyone that has a functional valve.  I'm doing a rebuild from a while ago and think I have misplaced some parts.  Also, a source for new one would be great too.
I'll attach a photo of the one I have.
Thanks.
Offline srodster
Re: 84 K30 Rear Proportion Valve Photos needed
« Reply #1 on: May 25, 2014, 01:36:18 pm »
More photos to understand better.......
« Reply #2 on: May 25, 2014, 02:01:12 pm »
This help, BTW most people bypass this especially if you are going to lift it...
Offline srodster
« Reply #3 on: May 25, 2014, 02:53:48 pm »
Yah, can I get another one on the left side of the valve to understand where the bracket that holds the rubber line from the pumpkin attaches to?  Is it the frame?
(My issue is that I have a k30 suspension with a c20 frame (cc, longbed))
And trying to make sure parts and pieces match up.  Don't know why I decided to do this, but I did....., about 18 yrs ago, and now trying to make progress before my Wife leaves me...., ha.
« Reply #4 on: June 04, 2014, 10:09:09 pm »
I don't know if I can find one, but why not just eliminate it...
Offline srodster
« Reply #5 on: June 05, 2014, 08:27:03 pm »
That is certainly an option, but I may need a little coaching on the correct hook-up, and do I have the correct valving left, if it is removed, or do I need a different one........  I have never dealt with that side of it before.
« Reply #6 on: June 05, 2014, 08:53:37 pm »
This help?  Found it on the net...
« Reply #7 on: July 05, 2014, 09:53:57 pm »
First thing I do to every truck I have ever got that still has that is chop it out. Run the brake line directly to the flex hose.
