Author Topic: 82 full size blazer 4x4  (Read 4434 times)
Offline harvardman
« on: May 25, 2014, 01:36:03 pm »
greetings all i am trying to help a friend that got screwed by a local shop .. his truck was gutted for restoration and now needs to be put back together ... my problem is with the wiring  harness has been removed and cut up ...  i am trying to identify what the wires are for that i havent figured out and would appreciate if anyone has engine compartment shots that show the harnesses and ac system.. any help would be great .. thanks
Re: 82 full size blazer 4x4
« Reply #1 on: May 25, 2014, 01:43:08 pm »
Any pictures you get will be loomed wire so you want be able to see anything.  There is complete wiring diagrams in the tech section showing were all of them go.
Otherwise you need to show up what you have questions on.
Offline harvardman
« Reply #2 on: May 25, 2014, 01:48:20 pm »
thank you for the tip .. i am going to take some pics and post here for help .. thank you sir
Offline harvardman
« Reply #3 on: May 26, 2014, 07:17:27 pm »
anyone know what this piece of harness is for and where in the harness it was cut from ?
« Reply #4 on: May 27, 2014, 10:31:21 am »
     Can you take pics of the socket ends, so we can see how many pins and what the actual ends look like, the more the merrier.
« Reply #5 on: June 04, 2014, 09:59:23 pm »
Ditto on what bake said...  closeup of the ends.
