Author Topic: TV Cable Help  (Read 3423 times)
Offline LTZ C20
TV Cable Help
« on: May 28, 2014, 11:04:21 am »
Ok guys, here's the deal. My TV cable is to short to reach the carb. Some of you know I have a new engine in my truck (79 C20, std cab long bed). I have installed a 89 700R4. So for has gone pretty good. Now I installed the tv cable at the trans, then hooked it into the bracket on the intake and it doesn't reach the linkage. Note: carb is a Holley 4160 series 600 cfm electric choke, pt #0-80457S.
At relaxed position it's about 6 inches or so to short, at fully extended positions it's about 3 inches or so to short. I know you can't run it fully extended because it messes with the line pressure and all that.
Does anyone know of an aftermarket cable or cable from a big block is longer or some kind of other cable type that will fit? Can I build a little extension arm that bolts to the linkage that will just extend the attaching point back closer so I can join it up and get it adjusted?
LTZ Cheyenne C20
Offline jetmech
Re: TV Cable Help
« Reply #1 on: May 28, 2014, 11:21:24 am »
Just ran into a similar problem on my 350 with Edelbrock carb and intake. The stock TV/throttle cable bracket won't work with my combination. I chose to buy a bracket rather than trying to modify a stock bracket. Also had to buy a piece of linkage to bolt to the carb to provide the correct geometry for the TV cable travel. Holley probably makes linkage and brackets for your setup too.
'86 Sub and '86 SWB C-10
1990 454 SS
Offline LTZ C20
Re: TV Cable Help
« Reply #2 on: May 28, 2014, 12:38:55 pm »
Oh really? I know they make brackets. I actually used the stock bracket, cut it in half and then bent them a little. So spray paint and good to go. They look good and work good. I'm gonna check on the Holley linkage. Thanks.
LTZ Cheyenne C20
Offline LTZ C20
Re: TV Cable Help
« Reply #3 on: May 29, 2014, 01:33:16 am »
Got this problem fixed. Found a piece of small flat bar steel at home. Cut to bout length, 1/4 inch hole on either end, problem solved. Seems to work good too. I got the cable set properly.
Anyone know how to re-adjust or take the slack out of the gas pedal cable?
LTZ Cheyenne C20
