Author Topic: putting aftermarket stereo in 76 c10, need to power memory  (Read 4109 times)
Offline aleighs1990
« on: June 02, 2014, 09:22:05 pm »
i have installed an aftermarket stereo in my 76 model c10. everything works as it should, except the unit has no memory. i tried connecting the memory wire to my fuse block where it's marked "radio", but still no memory. how should I have this hooked up to give the stereo memory when the truck is off?
Re: putting aftermarket stereo in 76 c10, need to power memory
« Reply #1 on: June 02, 2014, 09:28:32 pm »
Right or wrong I tap into the orange wire from the cigarette lighter
Offline scorn86
« Reply #2 on: June 02, 2014, 10:09:09 pm »
The memory wire for radios requires a constant hot to work properly.
Offline rich weyand
« Reply #3 on: June 03, 2014, 12:35:33 am »
That will work.  Any of the BAT taps in the fuse block will work.
