Author Topic: Steering box woes  (Read 6767 times)
Offline Dan75k20
Steering box woes
« on: June 04, 2014, 03:27:50 pm »
So I have owned the  75 k 20 since last august I have only been driving it daily since January 1st since then I have been just keeping it on the road and safe as I can make it roll down the roads.The po cobbled this thing together.I noticed that on Monday my steering started getting a little sloppy! So I drove about 6 miles to pick up supplies went to pull out of the parking lot at the paint store and bang . two of the three bolts ( supposed to be 4 ) that hold the steering box to the frame snapped. All I could do is put another bolt into it to get it to steer so I could go to work a mile or so down the road so here is the steering box with the 2 broken bolts
The frame looks goodhere is the problem the spacers were never installed with the bolts1 spacer and 3 bolts I have crossmember spacers from my old 84 that are the same size hopefully I can get the broken bolts out of the steering box .I am also installing new draglinks off to the parts store I go!
Sent from my Nexus 5 using Tapatalk
new draglinks I had to go to auto zone and buy made in China duralast parts but I can not wait for 4 days for advance to get them I have to go to work i n the morning and yeah its raining lol when it rains it pours the broken bolts came out with ease
« Last Edit: June 04, 2014, 08:05:02 pm by Dan75k20 »
Re: Steering box woes
« Reply #1 on: June 04, 2014, 07:27:08 pm »
     Well that is good news that the broken bolts came out easily, make sure you use grade 8 bolts and this should not happen again.
Offline Dan75k20
« Reply #2 on: June 04, 2014, 07:44:28 pm »
Bake they were grade 8 just no spacers and one was 1/4 inch too its back together thank goodness to my trusty underhood light   I want to order the box brace also and do cross over steering with sway bar link disconnects and add 36s for off road use only
« Last Edit: June 04, 2014, 08:06:34 pm by Dan75k20 »
