Author Topic: Cabs  (Read 3347 times)
Offline jfrits98
Cabs
« on: June 07, 2014, 11:19:23 pm »
Are the cab from a 73 the same as the cab from a 83?
Offline Engineer
Re: Cabs
« Reply #1 on: June 08, 2014, 04:20:45 pm »
Not exactly.
They can be made to work in place of each other. The biggest difference being where the hood and fenders mount on the outer edges of the cowling.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Re: Cabs
« Reply #2 on: June 08, 2014, 06:13:26 pm »
     If you do switch cabs newer/older or vise verse, you will need to use the cab mounts of the year of the cab.
Re: Cabs
« Reply #3 on: June 10, 2014, 06:53:23 pm »
Nothing at the firewall where the hood mounts is the same.  So going from a 81-87 cab to a 73-80 cab on a 81-87, you will have to modify the cab for the hinges.
