4 Wheel Drives
U-joint help ASAP please!!!
Topic: U-joint help ASAP please!!! (Read 15585 times)
thefarmboy21
June 11, 2014, 09:04:15 am »
A friend of mine just recently aquired a cobbled up mess of a Chevy. Long story short, he's been to every parts store in the tri state and personally inspected/mic'd their universal joint inventory......NONE are the same. Yesterday he went to 4 stores, all different companies and took all the googled part numbers for the 73-87's he could find so we need HELP!!! Here's what we know about it:
Cab/title is an 86 GMC 1/2 ton 2wd. Sitting on a 4x4 chassis of unknown origin. Has a 350/350 combo backed by the NP203 full time trasfer case. Has a Corp 14 full floater in the rear and I'm not sure if it has the 44 up front or the odd looking 10 bolt.
The U-joint we need mates the rear shaft to the 14-bolt rear. Also it's what most people call a "$#*() joint" Joint is narrower than tall and has two differen size bearing caps as well. Thanks in advance!
AMSOIL DEALER # 5583011
86 Chevy K20 Custom Deluxe-Grandpa bought it new 11/20/85
77 Chevy K10 Custom Deluxe-Dad's first truck
69 Chevy C30 flatbed-Grandpa's farm truck
1950 International L-112-Grandpa bought it new, parked in 1963
SomeTexan
No such thing as too much hp
Re: U-joint help ASAP please!!!
June 11, 2014, 09:22:34 am »
Find a shop that builds axles or driveshafts. They should stock or be able to get the conversion u-joints. Bring them the shaft and the yoke.
86 swb c10, LQ4/glide with 80mm turbo
thefarmboy21
June 11, 2014, 10:34:36 am »
Well I just would've thought it was a stock u joint for one ton or a half ton but we can't find it. Anyone know if there's a conversion joint for a half ton driveshaft to the corp 14?
SomeTexan
June 11, 2014, 11:06:59 am »
I know there is, just don't know a part # offhand. Find a spicer part number for both u-joints, then google the conversion u-joint part number. Or call a driveshaft shop and ask if they have them. Should be fairly common.
thefarmboy21
June 11, 2014, 11:33:02 am »
I found a site that has all of them.....waiting on the specs from him to cross it over.
June 11, 2014, 11:46:23 pm »
see if these help,
these are common u joint conversions for gm. take the u-joint to NAPA and give them the numbers with the "X"
NAPA part numbers
1330 /1350 = 5-648X
1310 /1350 = 5-460X
1310 /1330 = 5-134X
the "X" is part of the part number so they need that also
jesse79
June 14, 2014, 11:47:18 pm »
I think i know of the joint it is a 1350 on one end i cant rember the other but it is the same size as a 67-76 ford
We used them when putting 14 bolts in fords i will look i might have one one the shelf it was a spicer or nepco
Also call around to a drive line shop thats how i got mine and the guy sid it was a gm joint
jesse79
June 15, 2014, 10:48:59 am »
I looked in the shop ans no luck
If you need a part number let me know i can get it for you
In eather a spicer or nepco or a napa one
I have used all 3
jesse79
June 18, 2014, 10:07:59 pm »
Did ya get figured out?
thefarmboy21
June 20, 2014, 03:27:35 pm »
He thought he did, but I talked to him today after he tried it and still not right. I haven't been able to meet him to mic it myself.
pholliday1
1990 V3500 Crew Cab
June 20, 2014, 03:38:23 pm »
They do make what they call a "conversion" ujoint I know napa has them and there have been some posts on them you can also try Randy's Ring and Pinion. I'm sorry but I don't know the parts numbers
thefarmboy21
June 23, 2014, 10:15:00 pm »
He finally brought it to me and we mic'd it out....should be a 3-3140 series.
skinu
June 28, 2014, 02:07:53 pm »
THEY CALL MINE A HYBRID JOINT AND I THINK ITSS A 377 FROM NAPA I LOOK AND POST,FIND WHERE AND HOW TO MEASURE YOKES TUBES ECT AND CHECK THAT SECTION IN THE BACK OF NAPAS UJ BOOK WAS WHERE I GOT MINE ,ALSO IF THERES TO MUCH DIFF CHANGE THE YOKE OUT ,WATCH FOR BINDING @ AT ALL SUSPENTION ANGLES ALSO,THEY DO MAKE MANY DIFFERANT HYBRIDS I DO KNOW THAT.
thefarmboy21
June 30, 2014, 08:29:47 pm »
Yea, we got it....it was the 3-3140. He got two from Autozone. I can't remeber what Napa's part number was. We did learn that he has parts from at least three different trucks, if not more. Regardless he took it to a big rock buggy competition and said it did fantastic through the mud. Gears and maybe a diff cam are I'm the near future. Thanks for all the help!
4 Wheel Drives
