Author Topic: Hurst conversion  (Read 6741 times)
Offline 77c15
  • combustion=suck, squeeze, bang, blow
    • My cardomain site...
Hurst conversion
« on: August 30, 2004, 12:00:00 am »
I recently came across a steal: an older model Hurst 3-speed column-conversion shifter. Now, does anyone have any ideas on how to hook up the linkage. I already know that the shift pattern's gonna be reversed because of the location I mounted it (about 6 inches from my lead-foot leg for easy access from the IROC buckets I have in it!). It came with linkage that sort of unscrews to adjust length, but they're not nearly long enough. I guess the guys at Hurst(Mr.Gasket Co., now) must've thought every truck was gonna use the bench seat so the shifter would be mounted closer to the factory linkage. Any help would be appreciated. Thanks!
Offline roundedline
Re: Hurst conversion
« Reply #1 on: August 30, 2004, 10:14:00 pm »
The outside rod should go to the 1st/2nd arm and the inside should go to 3rd/rev.  This is from memory.  The shifter should mount to the rear of the trans.  The adjustment is to get neutral center, not to move the shifter forward.  They all sit back new where the bench would be.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline 77c15
shifter woes
« Reply #2 on: August 30, 2004, 11:14:00 pm »
Thanks, rounded line, but as I stated: the shifter is in, i'm just having trouble with the linkage. The srew-type rods aren't long enough to reach the trans. even when they're extended all the way out. Can anyone think of a way to hook up any kind of linkage? Thanks!
Offline DnStClr
Re: shifter woes
« Reply #3 on: October 27, 2004, 12:00:00 am »
Can you take the linkage to a machine shop and have them make a new threaded rod for the length you need? It sounds like a left hand thread.
Don
87 Chevy Silverado
Offline roundedline
Re: shifter woes
« Reply #4 on: October 27, 2004, 12:35:00 pm »
If you modified the location of the shifter, you will have to get new rods as the stock ones were made to fit in the normal mounting location.
Project Su
Jimmy 2WD Project
