Author Topic: 84 k10 timing issue? Misfire under load  (Read 9524 times)
Offline andyc1121
« on: June 11, 2014, 10:55:42 am »
Hey guys,
Had my truck running good I thought until a mechanic set my timing back and now it misfires under load, my timing when I got my truck back was 6btdc and would misfire bad on cylinder 6, 7, 8 around 1500-2500rpm. Now my initial is about 16 deg. Another issue I'm having is when trying to set the total timing it retards and I can't get a steady reading with a timing light. New plugs, coil, ignition module, year or so old msd 8mm wires n same with cap n rotor.  Here's a video of it, you can hear the popping sound.
http://s1283.photobucket.com/user/andyc891/media/160_zps9f89cd45.mp4.html
Re: 84 k10 timing issue? Misfire under load
« Reply #1 on: June 11, 2014, 09:18:55 pm »
    The video was pausing too much for me to see it, did you try to set your timing back to where it was before the mechanic reset it ?  Are you plugging off the vacuum advance when you are setting it ?
« Reply #2 on: June 11, 2014, 09:54:25 pm »
Couldn't really hear the popping clearly enough from the vid - is it coming from exhaust or intake?
Four things to check:  1) make sure the dampener hasn't spun on the hub, so you are setting the timing accurately, 2) check rocker and valve motion for a cam going flat, 3) use a different timing light - you described mistriggering of the strobe, and 4) any chance one or more spark plugs were cracked during installation?
« Reply #3 on: June 11, 2014, 10:54:38 pm »
did this "mechanic" test drive the truck after and thought it was ok?
Offline roundhouse
« Reply #4 on: June 12, 2014, 07:59:51 am »
I never bother with a light
Just advance it a little. Take it for a full throttle test drive up a hill.  If I doesn't ping then advance it a little more
Do this till it pings then back off just a little
You can also set it with a vacuum gauge  adjust for max vacuum at idle will be close to the best timing
My 74 Bronco with a fuel injected 5.0 from a 90 mustang has 44* advance  according to the light
But it Runs great
Offline roundhouse
« Reply #5 on: June 12, 2014, 08:00:47 am »
But it Runs great
However misfiring under a load sounds like a bad cap or rotor or plug or wire
Offline andyc1121
« Reply #6 on: June 12, 2014, 08:19:33 am »
Hey guys,
Thanks for all the help, when I get back to town gonna try roundhouse's advice n see what happens. Irish, I doubt he took it for a test drive Bcuz when I left the shop it was misfiring a lot so I went back n picked him up for a test drive n he said it was a bad fuel pump. So I changed it and no better so I upped the timing and it ran better. The mechanic said my initial was at 21-22 deg n kinda pinging but it ran fine n accelerated good no misfire or ping.. Umm truck has a new harmonic but it's not the right size but I don't have timing tape that's the right size on it n marked tdc on the balancer.
« Reply #7 on: June 12, 2014, 08:19:38 pm »
Hey guys,
      Bad fuel pump ? = bad mechanic  ;)
« Reply #8 on: June 12, 2014, 10:52:01 pm »
Hey guys,
X2
when was your last tune up?
Offline andyc1121
« Reply #9 on: June 12, 2014, 11:21:38 pm »
Ya bad mechanic is putting it nicely lol I actually had the same misfire when I had a plug wire fall off a spark plug last winter going up a hill, put the wire back on n it was fine.. Even told the mechanic that n he swore it was the fuel pump. Last tune up was about a month ago new plugs, wires, coil, ignition control module( ran better after icm), fuel filters. The truck has a stock 81 Camaro 350 with newer gasket n seals, would a holley 670 street avenger carb with edelbrock performer rpm intake(high rise) n shorty headers cause the engine to need more or a different timing? Last time the timing was set a mechanic friend did it by ear. I should have the weekend off so I'll go thru and check the basics and what you guys suggested and report back, thanks for all the help guys I really appreciate it.
Spelling mistake in my last post, I do* have msd timing tape on the harmonic that's the right size for the harmonic.
« Reply #10 on: June 12, 2014, 11:29:26 pm »
a mild 350 engine wouldnt need more that 600cfm. have you inspected your plugs lately?
Offline andyc1121
« Reply #11 on: June 14, 2014, 03:01:05 pm »
Hey guys,
Spent the day yesterday tearing into her and turns out my distributor had lots of play, you could see on the cap how the rotor was moving up n down. Plugs looked good but changed the wires n plugs and it's a night n day difference! I set the total timing to 36 deg (no more bouncy timing while trying to set it) and it doesn't miss at all. Ended up going 4x4in last night n we got 2 Chevys stuck until 2am :) thanks for the help guys!
** installed new distributor to fix the issue.
« Last Edit: June 14, 2014, 04:06:42 pm by andyc1121 »
« Reply #12 on: June 15, 2014, 09:04:48 am »
     Worn distributor bushing on the shaft.  Glad you got it figured out and are now able to enjoy her.
