Author Topic: what oil pan are you running?  (Read 8619 times)
Offline 1bad72
« on: June 12, 2014, 01:24:24 pm »
I'm looking for a oil pan for my ls swap. The truck is getting a 4/6 or 5/7 drop so which pan is a safe bet for ground clearance? H2 or Muscle car pan? :-*
Offline Mtrhd329
Re: what oil pan are you running?
« Reply #1 on: June 13, 2014, 10:03:41 pm »
I bought a ctsv pan off eBay.  It made the pan almost even with the crossmember which helped a lot with ground clearance
Sent from my SPH-L710 using Tapatalk
« Reply #2 on: June 17, 2014, 01:36:47 am »
F-body pan should be shallow enough.
