Author Topic: Transmission Swap Help  (Read 5419 times)
Offline 2tone4by
« on: June 16, 2014, 12:25:49 pm »
I got a 78 4x4 with a three speed from factory I just can't get right, so I am looking to just put in a th350 automatic. I was wondering if all of the 4x4 transmissions back then were the same and will interchange with each other. I have found a trans and transfer case still bolted together, but the transfer case is not a np205 like mine, but is an aluminum one. Could you guys give me some info on what I am I getting into as for other parts such as cross members, adapters etc;.....all thoughts appreciated
Re: Transmission Swap Help
« Reply #1 on: June 16, 2014, 05:13:06 pm »
If you have a 3 speed column shift I am is desperate need of parts if you decide to swap to an automatic
Offline Dan75k20
« Reply #2 on: June 16, 2014, 07:15:32 pm »
Do you have a 3 speed or sm465 granny low plus 3 gears ?
Offline 2tone4by
« Reply #3 on: June 16, 2014, 10:21:18 pm »
I have a three speed tremec transmission that came with the column shift.....I have had this truck since it was 6 months old and I have never seen another one
Offline 2tone4by
« Reply #4 on: June 17, 2014, 11:17:27 am »
Does anyone know if the 73-80 model 4x4 trucks all had the same th350 transmission in them, regardless of the transfer case or are the rear output shafts all a different length
« Reply #5 on: June 17, 2014, 11:55:30 am »
Different output shaft depending on what was behind them.
Offline roundhouse
« Reply #6 on: June 17, 2014, 06:46:06 pm »
I know a guy that bought a new one In 84 or so
Shortbed 2wd with the three on the tree
Had to order it I think
Offline roundhouse
« Reply #7 on: June 20, 2014, 09:33:05 am »
You tried adjusting the linkage ?
The ears on the column under the hood have a home in the center of them
Put the trans linkage in N
Loosen the adjusting nut on the trans
Put the levers on the trans in N
You can feel em pop into N
Put a drill bit thru the two holes.t
Then tighten The nuts
Offline blazing816
« Reply #8 on: June 23, 2014, 09:11:37 am »
You also need to be careful on what year trans you get, because the crossmember will be different. The (not so bright) PO of my truck put an older 75 TH350 in my 86 that had a 700r4 and the crossmember was wrong and he had it all "hillbilly" attached. Took me awhile to figure out the year of the trans and what brace and mounts I need. So just know the year of the trans when you buy it.
