Author Topic: Pillar Pod final questions  (Read 61071 times)
« on: June 16, 2014, 07:13:13 pm »
Last and final questions..
1) currently these are sized to fit Autometer gauges of 2-1/16, that means others won't slip in and be held.  Should I make is smaller and have a step in it on where to trim to for the Autometers or just make it fit and anyone using other generic gauges have to use the clamp set?  (many people don't clamp these)
2) Is everyone going to be drilling holes in their pillar to route the wiring/hoses?  What is your plans on routing?
3) How is everyone planning on attaching these? What is you plan on attaching these?
I am ready to fire the trigger on this and this is how I planned to go about it.
1) make it fit the Autometer body
2) drill a pass through hole if required in the pillar or for wiring wrap it under
3) I plan to permanently mount mine with either epoxy or plastic weld.
Offline cvbear
Re: Pillar Pod final questions
« Reply #1 on: June 16, 2014, 08:02:00 pm »
1. Autometer sizing is fine with me
2. I planned to drill a hole for the wiring
3. I planned to screw it on, but would not be opposed to epoxy/plastic weld.
Excited about the progress, let me know when these are ready.
« Reply #2 on: June 16, 2014, 08:42:39 pm »
  • Any standard 2-1/16" gauge should fit the 2-1/16" hole.  But, if the holes are slightly undersized they can be shaved for a custom snug fit to suit.
  • For wires to be completely hidden they will need to route under the factory trim.  A pass-through hole seems imminent.
  • I assume that either the screw locations for the factory pillar trim will be left uncovered by the gauge pod -OR- at least one trim screw will pass through the pod strengthening the mount(?).
    As an afterthought, three or four reinforced plastic bosses on the "underside" of the pod might provide an excellent mounting option for "hidden" screws that come up through the factory pillar trim from underneath.  Of course, the pod would have to be secured to the pillar trim with the screws before mounting the trim to the A pillar.  The advantage in screws is the option to remove the pod, but still provide a secure mounting.  A conservative bead of paintable silicone caulk will seal against any light leaking from the back of the gauges and/or warning lights.  Epoxy, although effective, is a little less forgiving.
« Reply #3 on: June 17, 2014, 01:46:16 am »
Some of the generic 2-1/16" gauges are smaller, although the bracket will fit to hold it.  I tried about 3 from Autozone and Advance.
Drilling is inevitable, but some have cringed on that before...  I need a gauge, so I will be drilling.
I have thought about screws also, just not sure yet.  I do know that any form of tape will not work in any type of heat.
As for a hidden boss, they are just to thin and would need to be screwed from the outside in.  No holes will be covered by the pod.
Keep it coming...
« Reply #4 on: July 01, 2014, 10:03:34 pm »
Someone suggested no holes in the pillar and let the owner cut them out.  I am opposed to this, opinions?
« Reply #5 on: July 02, 2014, 12:24:32 am »
If you mean blank gauge locations, so the gauge mounting holes aren't cut out, I am also opposed and think this would be a source of ongoing complaints.
« Reply #6 on: July 02, 2014, 12:47:10 am »
Yes exactly.  Still trying to nail down the attachments.  Suggestions welcomed.
captkaoscustoms.com
squarebody.biz
« Reply #7 on: July 02, 2014, 02:22:26 am »
im kind of confused on how the other gauges will fit if the hole is to big for the face to catch. not big on gauges so i dont know what other sizes or how these even work. would the autometer be snug and slip into place while others will be too small for the hole to be snug so you have to use the "u" bracket that comes with them?
« Reply #8 on: July 02, 2014, 07:32:00 am »
I am going to make the hole smaller than the gauges so they can be trimmed ( actually sanding may be better) to make them fit snug.  The Autometers are 2.0625" the hole will be 2", so we are talking fractions.
captkaoscustoms.com
squarebody.biz
« Reply #9 on: July 02, 2014, 10:21:29 am »
So the faces are the same its the body thats different dia?
« Reply #10 on: July 02, 2014, 04:21:57 pm »
The pillar doesn't change at all.  The face needs a hole to mount the gauges.  The autometer interference fit is 2.0625, the smallest one I ran across that was cheap was 2.045".  There isn't enough difference to make it 1/32" smaller so I just made it 2" even and any gauge can be sanded  to fit.
Biggest thing I need feedback on is attachment.  I need to tell them something ASAP to get this moving...
« Reply #11 on: July 02, 2014, 05:43:07 pm »
I would like to see the attachment points sufficiently reinforced that they won't crack with tightening or minor flexing as the pieces conform to one another, or as they distort with temperature extremes such as baking in the sun.  I envision #6 oval head trim screws at the four corners of the pillar, perhaps, augmented by a pair in the center for 4 to 6 attachment points, making the gauge mounting fully supported and very solid.
Edit:
Although gauges aren't heavy and the pod can easily be retained by two screws, four-plus gently tightened screws should decrease strain while maintaining conformity between the pod edges and the trim.
« Last Edit: July 02, 2014, 08:43:29 pm by bd »
« Reply #12 on: July 02, 2014, 09:28:52 pm »
The final part will be about the same thickness as the current part so they should hold together with screws.
I am just thinking about the underside connection...
captkaoscustoms.com
squarebody.biz
« Reply #13 on: July 02, 2014, 10:23:43 pm »
...I am just thinking about the underside connection...
Sorry Chris, you lost me....  What underside connection?
« Reply #14 on: July 02, 2014, 10:55:17 pm »
Bolted from the backside.  The only issue is having to locate the holes.
captkaoscustoms.com
squarebody.biz
