Author Topic: GM Preformance Crate Engine  (Read 10012 times)
Offline swilliams
« on: June 18, 2014, 12:40:55 am »
What is the easiest way to tell if my crate engine had dished pistons.
Offline swilliams
Re: GM Preformance Crate Engine
« Reply #1 on: June 18, 2014, 12:43:50 am »
sorry HAS not had. The engine was installed in the past 5 years.
Offline rich weyand
« Reply #2 on: June 18, 2014, 01:20:09 am »
Look for the engine ID number.  That will tell which crate engine it is, and then you can look up the pistons.
The engine ID number will be on the front of the deck on the passenger side, right in front of the head.  That is probably under the alternator, but it's not that hard to get to.
Offline swilliams
« Reply #3 on: June 18, 2014, 01:31:14 am »
Thanks for the info.
Offline swilliams
« Reply #4 on: June 18, 2014, 02:23:23 am »
This is the only # in the alt area. I looked it up and got nothing.
1M1119
4VP.
Offline rich weyand
« Reply #5 on: June 18, 2014, 10:16:20 am »
See the second answer to this post:
http://www.chevytalk.org/fusionbb/showtopic.php?tid/296901/
So it is 1=GM, M=Mexico, 11194= November 19, '4 (1994 or 2004), and VP = 350/260hp crate engine, #10067353.
That's the base crate engine, see description here.  Definitely dished pistons.
http://www.jegs.com/i/GM-Performance/809/10067353/10002/-1
« Last Edit: June 18, 2014, 11:46:26 am by rich weyand »
Offline swilliams
« Reply #6 on: June 18, 2014, 11:34:21 am »
knowledge is power. I tried several places to look the number up and found nothing. I did not try Jegs. Thanks again.
Offline 76StepSd
« Reply #7 on: July 08, 2014, 10:30:40 am »
i wish i could ID my 350 unfortunately when decking is done on the block that number by the alternator tends to get shaved off. :-(.....so i dont know what it has but i guess it doesnt matter since the motor was rebuilt for the PO.
Offline swilliams
« Reply #8 on: July 08, 2014, 12:45:09 pm »
That is part of the reason I wanted to know. To see what parts I have and what I can upgrade.
Offline 76StepSd
« Reply #9 on: July 08, 2014, 12:49:30 pm »
i do know it has a comp cam part# 12-211-2....which is a .470 int & Exh....with duration at 224 for int & exh also...i have the print out from comp cams when he purchased it.
Offline swilliams
« Reply #10 on: July 10, 2014, 10:01:02 pm »
That is the cam I have.  Its a good one: Help with a cam.
« Last Edit: July 11, 2014, 12:39:02 am by bd »
Offline rich weyand
« Reply #11 on: July 11, 2014, 01:18:01 pm »
In a stock GM crate, 12-211-2 dyno-simulates at 306 hp at 4500 rpm and 395 lbft at 2500, with 260 lbft coming off idle at 1000 rpm, and the torque curve starting to drop off at 4000 rpm.  Nice fit for the CK.
Offline 76StepSd
« Reply #12 on: July 15, 2014, 04:32:26 pm »
Interesting gonna check fir numbers on the heads to see what is on the engine
