Author Topic: Worn rear end?  (Read 6147 times)
Offline 73 WHITE KNIGHT
Worn rear end?
« on: March 30, 2004, 09:10:00 am »
With the drive shaft disconnected from the rear, How much "play" should there be? Im getting a strong vibration on takeoff, but when I accelerate the vibration stops and there is a squeeking noise. I am changing the u-joints but there seems to be alot of play in the rear. I can rotate the yoke about 1".
Offline aprice
re worn rearend
« Reply #1 on: March 30, 2004, 08:57:00 pm »
well i can tell you that 1" is too much, last time i changed the u-joints in my truck i had aboud 1/4" i think or maybe less
Re: re worn rearend
« Reply #2 on: March 30, 2004, 11:50:00 pm »
It wasn't the rear end. the carrier bearing had siezed (split drive shaft). Thanks for your input!
