Author Topic: Tire recommendations 85 c10  (Read 4377 times)
Offline qmr55
« on: June 23, 2014, 10:43:10 pm »
Working on an 85 C10 doing a 4/6 drop. Looking to do 18x8s all around. Just your basic torque thrust ( see here http://www.treaddepot.com/wheel/ar105m8873b.html )
Will those work with the lowering kit and not rub anywhere? Anyone have a tire recommendation?
Not sure if I covered everything if you have any questions to properly answer it just ask!
Thanks ahead of time guys!! Hoping to get this project finished up soon psyched!
Re: Tire recommendations 85 c10
« Reply #1 on: July 01, 2014, 11:04:06 pm »
What backspacing, if you match the factory in front with the 8" you will be fine, the rear doesn't matter and if you can get less it will put the wheel "out" like it is on front.
Depending on the size of tire anything under 29" should work ok.
