Author Topic: dual tank to single tank fuel guage wiring  (Read 4149 times)
Offline brownjimmy83
« on: July 01, 2014, 06:08:35 pm »
Fixing to hook up guage in my 83 c30 last owner cut all the wires off framerail and switch valve. I need to know which wire runs inside cab to operate guage
Re: dual tank to single tank fuel guage wiring
« Reply #1 on: July 01, 2014, 10:19:37 pm »
Should be a pink wire.
All the wiring diagrams are here:
http://forum.73-87chevytrucks.com/smforum/index.php?topic=11766.0
« Reply #2 on: July 01, 2014, 10:27:18 pm »
Thank you actually figured it out a little bit ago. I just started grounding wires he cut until the gauge moved.
I also discovered that i have a bad resistor on back of fuel guage causing it to show 1\4 tank even when full.
Part number is w-586 if anyone else has that problem
