Author Topic: Ignition timing on a big block  (Read 2958 times)
Offline bigjoe62b
« on: July 02, 2014, 12:59:29 pm »
Hi, I have an 86 stepside with a 454 and a th350 gearbox. I was wondering about the ignition timing marks on the stock cam cover. I see the 0 for top dead centre but for setting the ignition timing how would I go about setting the idle timing on it. I was going to run about 12 -13 degrees of idle timing.
Thanks guys
Offline ehjorten
Re: Ignition timing on a big block
« Reply #1 on: July 02, 2014, 01:16:17 pm »
Your timing tab should have numbers for -0-, -4-, -8-, -12- on the upper side, or BTDC.  I believe every mark on the timing tab is 2° and ever peak of the saw-tooth point is 4° apart.
Alternatively, you could use a dial-back timing light or put a timing tape on your balancer.
Depending on the condition of your harmonic balancer your TDC mark may or may not be accurate.
-Erik-
Offline bigjoe62b
« Reply #2 on: July 02, 2014, 02:36:22 pm »
Oh yeah. I couldn't see the marks on it but I can see them now.
