Author Topic: What would cause a temp gauge to suddenly stop working?  (Read 9988 times)
Offline Stewart G Griffin
« on: July 05, 2014, 07:19:51 pm »
Do you have any ideas on why a temp gauge would stop working suddenly?
It's a mechanical gauge  and when i first noticed the gauge was not registering it made me wonder if i had enough water in the system, so i parked it and yes i was real low.   i added some with the engine still running ( i always carry a few jugs of water in back) to bring the radiator back up.  Since then the temp gauge doesn't work.
The engine did not overheat as far as i know---it runs fine.   It turns out one of the heater hoses was leaking and this caused the water level to go way down.  But this has been fixed.
« Last Edit: July 05, 2014, 07:22:00 pm by Stewart G Griffin »
Re: What would cause a temp gauge to suddenly stop working?
« Reply #1 on: July 05, 2014, 07:24:14 pm »
P.S.
The sender for the gauge is in the intake manifold near the water neck.  i don't know if this helps.
Offline jaredts
« Reply #2 on: July 05, 2014, 07:28:49 pm »
Did you crack the sender to make sure fluid comes out?  Could be an air pocket maybe.
« Reply #3 on: July 05, 2014, 11:19:35 pm »
air pocket would be steam and it should still read it. a pinched line? never seen a mechanical one fail
Offline FlatBlack77
« Reply #4 on: July 06, 2014, 12:11:22 pm »
check the entire length of the line and check for any damage. depending how you have it routed maybe it got against the exhaust manifold and melted?
Offline BADAZ chevy guy
  • Chevy! My drug of choice!
« Reply #5 on: July 06, 2014, 02:20:28 pm »
I've never seen a mechanical temp gauge. How does it attach to the motor?
Offline bd
« Reply #6 on: July 06, 2014, 03:07:52 pm »
They use a one-piece capillary tube filled with fluid that's permanently attached to both the gauge and a thermal bulb that threads into the water jacket.  Think of an old fashioned mercury thermometer.
« Reply #7 on: July 06, 2014, 04:34:06 pm »
Okay. So it heats up and builds pressure which in turn moves the gauge. Interesting. So, I would think a leak then.
Offline bd
« Reply #8 on: July 06, 2014, 05:18:17 pm »
Possibly; or the sensor isn't immersed in liquid.  Heat transfer between liquid coolant and the sensor is far better than heat transfer between a hot gas (such as steam) and the sensor.
Offline FlatBlack77
« Reply #9 on: July 06, 2014, 07:34:19 pm »
if the line checks out alright you can move the probe to the side of the block and see if it makes a difference(doubt it will)
« Reply #10 on: July 06, 2014, 11:36:35 pm »
These things read even if they are just hanging in the engine bay. May not be accurate but they will read something. Buddy got a truck and I forget why but it had two temp gauges and was hanging off the booster and it would read 100°+
« Reply #11 on: July 07, 2014, 06:52:19 pm »
Yeah, mine doesn't read anything.  i am busy with work etc. but will check it out asap.
« Reply #12 on: August 02, 2014, 05:42:17 pm »
The line is not clear, so i can't check for fluid leaks.  No damage to the line either.   Any other suggestions?
Offline bd
« Reply #13 on: August 02, 2014, 07:18:56 pm »
Remove the temperature gauge bulb from the water passage and immerse it in near boiling water with a thermometer in it, so you know the water temperature.  If the dash gauge doesn't read within ~3%, replace the gauge.
« Reply #14 on: August 02, 2014, 10:41:52 pm »
ok
