Author Topic: What numbers on a ring gear tell you the ratio? (picture)  (Read 3838 times)
« on: July 21, 2014, 03:58:45 pm »
this is a picture of a 4.09 ring gear aka 4.10 its for the front
but to figure out the ratio of yours you take the last two sets of numbers 45-11. these are the ring teeth-pinion teeth. you devide the ring by pinion (45/11) and that equals 4.09090909 or 4.10. also if you see on the far right of the ring it says 9 but it really says 456 upside down i dont know why it says this but if your does dont pay no mind to it just the last two sets of numbers
Offline ehjorten
Re: What numbers on a ring gear tell you the ratio? (picture)
« Reply #1 on: July 22, 2014, 10:27:04 am »
Is this an actual question Irish, or are you just putting this out there for people to search and find?  Best and most reliable way to tell is to count the # of teeth on the ring and divide by the count of the # of teeth on the pinion.
No need to look for a number if you have the gears exposed so that you can count the teeth, but the number should still be there.
-Erik-
« Reply #2 on: July 22, 2014, 12:23:00 pm »
This is a FYI. When the gears are in the axle I can't never count the pinion. When you tell someone what numbers to divide some need a picture.
Offline pholliday1
  • 1990 V3500 Crew Cab
« Reply #3 on: July 22, 2014, 12:26:01 pm »
The 45-11.
