Author Topic: Upgrade questions for my 305  (Read 8169 times)
Offline 86SilveradoEric
« on: May 26, 2004, 11:46:00 pm »
I was just curious how big of a difference I would see in performance from my 305 if I put in a hotter coil or rebuilt my HEI with a kit and upgraded the sparkplugs?
I've often wondered if any of the lost throttle response I've suffered is caused by lack of proper spark.  I'm certain the coil is the original; I know the distributor is.  I have no other mods, and I run my truck on Chevron 93 octane.
Also I've been thinking of upgrading the intake and carb.  My truck has got all of the emissions @#%$ on it with the 4bbl Rochester, and I was curious if the Edelbrock Performer will help throttle response with the stock Q-jet.  If not, what's a good carb?
Thanks for your help.
1986 Chevrolet Silverado Pickup
Offline RSBAD454
Re: Upgrade questions for my 305
« Reply #1 on: June 18, 2004, 01:06:00 pm »
nice truck....i say upgrade motor........:smokin
Toys are my game
http://
Offline 77c15
  • combustion=suck, squeeze, bang, blow
    • My cardomain site...
305 performance
« Reply #2 on: June 18, 2004, 11:08:00 pm »
Upgrade you HEI to an Accel piece that's a stock replacement, run the 8mm yellow Accel plug wires and get a set of rapid fire plugs and you WILL feel a BIG difference in throttle response and a nicer idle. I did the above mentioned to a buddy of mines 305 in his '74 C10, and he had a 2bbl rochester. The idle note coming out the exhaust was incredible, it actually sounded meaner than most stock camaros.
Re: 305 performance
« Reply #3 on: August 16, 2004, 05:50:00 pm »
Sweet...thanks.
Offline jimfulco
Re: 305 performance
« Reply #4 on: August 16, 2004, 11:38:00 pm »
You may lose throttle response with the Performer, since its runners are larger than yours.  Even a stock 350 loses power on the dyno until ~3000rpm with a Performer swap.
Offline 1976Scottsdale
Re: 305 performance
« Reply #5 on: September 02, 2004, 08:10:00 pm »
Build a 377 stroker.  Great for trucks.
