Author Topic: 400 sbc build  (Read 6471 times)
Offline deano1977
400 sbc build
« on: July 22, 2014, 12:25:42 am »
Lokking to build a 400 sbc just do a cam intake and possibly springs looking to pull asuch power as possible going in a 77 c10 lwb t350 2500 stall with a 12 bolt unsure of gears
Re: 400 sbc build
« Reply #1 on: July 22, 2014, 11:06:32 am »
Do you have a question or just announcing a new project?
Offline Stewart G Griffin
Re: 400 sbc build
« Reply #2 on: September 01, 2014, 09:57:43 am »
If you have the $$$$,  Dart, GM, and others offer NEW 400 blocks.   But i think they are at least 2K.
Offline deano1977
Re: 400 sbc build
« Reply #3 on: September 22, 2014, 09:16:46 am »
im asking a question on best way to make max power with out doing anything to bottom end on my 400 sbc 511 casting and I would like to use stock heads tight budget and up grading from a 305
Offline deano1977
Re: 400 sbc build
« Reply #4 on: September 22, 2014, 10:06:24 am »
any help would be appreciated!
Offline Don5
Re: 400 sbc build
« Reply #5 on: September 22, 2014, 11:36:44 pm »
 I put one in my 79 GMC years ago. It ran pretty good back then. I used the following parts: Edelbrock Performer intake, Quadrajet carb, Blackjack headers, Crane Fireball 2 camshaft - no longer made :(, hi volume oil pump, double roller timing chain and stock heads.
This combo ran pretty good in my truck. A lot of people thought my truck had a big block but it didn't. I admit it, I ran it pretty hard too. The specs on the cam were a 290 duration and .454 lift. Since this cam is no longer made, I would look for something close. This combo would turn 5000 RPM easy and set you back in the seat. The truck really came alive when I kicked it. ;D Yeah I had a lot of fun in it.
 You want to make sure you have the correct balancer and flex plate for the 400. The 400 is externally balanced so this is critical. I would also suggest installing a shift kit with the off road option in it. I used the stock valve springs as well. If I was going to build a 400 today, I would use a Performer RPM intake with same parts. Good luck with your build. I hope this helps.
