Author Topic: 2nd gen chevy 14 bolt under 73?  (Read 3637 times)
Offline jhiggin
« on: July 23, 2014, 11:17:13 pm »
So this may be a newbie question. I've reed through the 14 bolt bible and can't seem to find what I'm looking for. A buddy has a good 14 ff that he will sell me for cheap. He sais it came out of a 1970 k20 so my question is would it be a direct fit under the rear of my 81 k10 or is the axle set up with different perches etc.. ??
Offline jhiggin
Re: 2nd gen chevy 14 bolt under 73?
« Reply #1 on: July 23, 2014, 11:18:26 pm »
Sorry meant to say 73-87 in title
Offline blazing816
« Reply #2 on: July 24, 2014, 10:19:28 am »
Yes should be direct fitment. Some of the 70s Chevy is a four-link suspension set up, but I believe that was only the 2wd (but just make sure it is not set up for four link and you should be good).
Offline Jason S
« Reply #3 on: July 24, 2014, 11:30:03 am »
Quote
To my knowledge, unless the 14 bolt was swapped, a 1970 K20 would've had a Eaton HO52 rear axle or a Dana 60.
You might measure the distance from the center of the spring pads on each axle also the total widths to make sure you don't need to move spring pads and of sufficient overall width.
Offline jhiggin
« Reply #4 on: July 24, 2014, 03:33:38 pm »
That's a good idea  jason s. And I do know it's a set up for leaves so I guess I get it and I can always sell it's it doesn't work out. Thank y'all!!
