Author Topic: Lifted Lifters  (Read 3239 times)
Offline enaberif
Lifted Lifters
« on: July 26, 2014, 06:34:15 pm »
I'm not sure what to really call this but I am in the process of swapping intakes to rid myself of the heavy ass cast iron manifold and finally got it off then I noticed this.
I have 3 circles that I am particularly looking at.
2 of the red circles shows the lifters unseated from their normal position than all the others. Is this normal? The other thing I found was a u shaped clip which looks like it may have come from a lifter.
The other thing of concern is the one push rod that is absolutely spotless that I have also circled in red.
Now before I really go and drop a bunch of money on this motor its a tired old 305 which I recently disocvered and thought was a 350. I can probably find a fairly cheap short block 350 for $200-300 and do a fairly quick swap with everything I already have.
Anyone have advice on what may have caused this issues?
Re: Lifted Lifters
« Reply #1 on: July 26, 2014, 07:44:01 pm »
Normal lifter movement.  The cam pushes them up an in turn opens the valve.
Offline enaberif
Re: Lifted Lifters
« Reply #2 on: July 26, 2014, 08:36:18 pm »
Hmm ok.. Finding a loose lifter clip tho.. Bit disconcerning.  But if you say this is normal.. But why only two?
Re: Lifted Lifters
« Reply #3 on: July 26, 2014, 08:53:40 pm »
Clips off are not good, could have wrong lifters, hard to say by the pictures.
Offline enaberif
Re: Lifted Lifters
« Reply #4 on: July 26, 2014, 09:36:39 pm »
I'm hoping by installing a new intake and gaskets and proper gaskets on the valve covers I can run this engine till it dies next year lol.
Clip was the middle one.
