Author Topic: passed leak-down test, oil burning mystery  (Read 2846 times)
Offline peterb
  • 75 GMC Sierra Grande 15; 86 Custom Deluxe 10
    • autoliterate
« on: July 27, 2014, 05:41:26 am »
I have a 1975 GMC with 350, auto trans. Have been burning oil. Blue puff at start-up but donut otherwise see smoke. Replaced valve stem seals. No change. Checked, some oil in plugs 1&3. Did cylinder leak test with mechanic. All cylinders ok. Checked (intake) valve seals again, looked fine. Didnpt check exhaust valve seals (though these were replaced 6 mo. ago along with intakes. Cannot figure source of blue cloud. If oil were leaking from gasket below say manifold wouldn;t truck be smoking all the time, not just blue puff at startup....thought it was rings but since leak test checks out fine....I'm puzzled.
Re: passed leak-down test, oil burning mystery
« Reply #1 on: August 17, 2014, 02:48:10 pm »
generally this is from leaking valve seals...
