Author Topic: 79 cab just set up for heat  (Read 6937 times)
Offline sameold
« on: July 27, 2014, 06:57:28 am »
On my 79' K30 scottsdale cab it's just set up for heat.
http://forum.73-87chevytrucks.com/smforum/index.php?topic=21690.15
reading the above tread it seems like Firefighter cut a new hole and flipped the heater core 180 so the tubes are more towards the driverside.
The 85 cab I have now has provisions for heat and A/C.
I forgot to take pic and I will post them later
Re: 79 cab just set up for heat
« Reply #1 on: July 27, 2014, 08:30:08 am »
      Is there a question or just a statement here ?
Offline sameold
« Reply #2 on: July 27, 2014, 08:49:08 am »
I am asking if all firefighter did was flip his heater core 180 and make a cover plate for it?
85 top, 79 bottom
« Last Edit: July 27, 2014, 08:55:35 am by sameold »
« Reply #3 on: July 27, 2014, 06:38:44 pm »
     I can not tell you if firefighter did that or Chevy did that in the different years.  Have you PM'd firefighter to ask him this question yet ?
« Reply #4 on: July 30, 2014, 12:26:03 pm »
Completely different heater box, outer fan box, heater core. Need to make a pattern from the AC cab, weld in sheet metal to match, then cut out what is left.
« Reply #5 on: August 17, 2014, 02:28:41 pm »
Firefighter removed AC from his truck and went to only head on it.
Those are the steps to make it work and you have to source a Heat only setup and get rid of the AC housing inside and out...
