Interior & Equipment
Door Panel Insert Studs
Topic: Door Panel Insert Studs (Read 10824 times)
DnStClr
August 07, 2014, 12:26:38 pm »
Here's a small dilemma I'm in the middle of-
I'm re-doing the interior of my 87. I used a vinyl covering on the door panel inserts. Here's a pic-
A few of the plastic studs on the backside were broken so I drilled them out with the idea of replacing them with 1/4 inch plastic rods, and then screw the thread-cutter nuts on to the new plastic rods.
But, of course, I can't find anybody who has the plastic rod. SO, l thought I'd make my own using a piece of 1/4 inch plastic tubing slid down over a 3/16 inch dowell. But that didn't work so well- the nut ate up the plastic tubing.
dumb idea anyway.
Does anybody have a source for the plastic studs that are on the insert panel or have you done this repair with something else that I can use to replace the broken ones?
Sorry about that fuzzy picture. I guess I resized it a little bit too much...
Last Edit: August 07, 2014, 12:33:19 pm by DnStClr
Don
87 Chevy Silverado
bd
Re: Door Panel Insert Studs
August 07, 2014, 01:03:59 pm »
Don, I experienced the exact same circumstances nearly 19 years ago. I tapped the holes and permanently installed 1/4" NC set screws of the appropriate length, using epoxy to firmly retain them in the plastic panel. I installed the screws so the socket heads were accessible from the back, then backing up the screws with an Allen wrench, used torque prevailing aero nuts and washers to retain the trim panels to the door panel.
DnStClr
August 07, 2014, 02:36:28 pm »
Hmmm . Wouldn't ya know - I've already drilled out the plastic bosses to 1/4 inch, thinking that I would easily find some replacement stud material. Well maybe I could go with 5/16" set screws.
Don
87 Chevy Silverado
bd
August 07, 2014, 03:00:33 pm »
So, use Helicoils or other inserts, such as the brass inserts used in wood....
DnStClr
August 07, 2014, 06:04:28 pm »
That's the answer- thanks Rich. It looks like a 1/4" helicoil won't leave me enough boss wall tho. . The boss is .510" dia. and the drill hole for the 1/4' insert is a .375" hole. If I drill for the 1/4" insert the wall will only be @ 1/16" thick. I'll use a 10-24 insert to get more wall thickness.
Don
87 Chevy Silverado
bd
August 07, 2014, 06:09:03 pm »
There ya go! Post up the results with pics.
DnStClr
August 07, 2014, 06:12:39 pm »
Will do. I suppose it's a pretty common problem with re-doing the insert panels.
Don
87 Chevy Silverado
DnStClr
August 08, 2014, 05:29:56 pm »
Well, here's what I'm using- a simple thread insert normally used for wood inserts. I wasn't able to find a 10-24" set screw long enough so I'm using brass screws.
After drilling the holes out to 9/32", I used a 5/16" lag bolt to put some threads in the hole. I put some threadlocker on the brass inserts and carefully threaded them into the plastic.
I attached the brass screws into the inserts to hold the panel. I had to cut the screws to 1/2" long.
And the finished look- I used a darker colored vinyl so it would match my seat. If it doesn't work out i guess I"ll start all over with a lighter colored vinyl...
Don
87 Chevy Silverado
bd
August 08, 2014, 05:43:54 pm »
That worked out really well! And, there's no concern about them ever breaking off again.
Thanks for posting that up, Don.
Chris, this would be a great addition to the Tech section.
bake74
August 08, 2014, 07:45:22 pm »
That is a great idea for the brass inserts, if you ever have to work on the panel again, should be easier next time.
74 k10, 77k10 Tom
August 17, 2014, 01:35:22 pm »
If you can make a single post of that and leave this here I can move it.
BTW I sell those panels already recovered in seat matching material. The reason all the other companies can sell it is I sacrificed mine.
I just checked the store and these apparently got dropped from an update or something, but I will add them for the future...
DnStClr
August 18, 2014, 03:48:57 pm »
I checked the store before I recovered the insert panels. I thought they were there too, but didn't see them.
All posts made into a single one -
Don
87 Chevy Silverado
dsgb610
August 18, 2014, 06:06:23 pm »
WOW man this looks amazing. This post is right on time. In the middle of doing my door panels.
DnStClr
August 20, 2014, 02:26:22 pm »
Have you re-coated the panels yet, dsgb610? I didn't spray a coat of clearcoat like some guys do. I've got a couple of paint chips from handling the panels during install, and wonder if the clearcoat would've protected them better.
Don
87 Chevy Silverado
