Author Topic: Pushrods......How bent is "bent"  (Read 2663 times)
Offline thefarmboy21
« on: August 11, 2014, 03:58:40 pm »
I was adjusting the valves on my motor today after a head swap and noticed that my rocker arms kinda had a shimmy to them while spinning the pushrods. I took one out and rolled it and it seemed fine. Then I put it against a straight edge and up to a light.....it has a SLIGHT bow. It mean I'm talking paper thin light exposure in the middle and then when rotated a little, slight exposure on the ends. So I grabbed a couple from two other motors randomly and got basically the same results. SOOO.....are they really considered bent? Or are they just straight within SPEC? Because I highly doubt parts store Melling ball tipped pushrods are as carefully tested as Comp Cams 7/16 hardened pushrods. This is basically a stock 350 with 9-9.5:1 compression and a Comp 4X4 cam with .447x.462 lift. Nothing special, just a truck motor that will rarely exceed 55mph. I just want to know if I need pushrods or not.
AMSOIL DEALER # 5583011
86 Chevy K20 Custom Deluxe-Grandpa bought it new 11/20/85
77 Chevy K10 Custom Deluxe-Dad's first truck
69 Chevy C30 flatbed-Grandpa's farm truck
1950 International L-112-Grandpa bought it new, parked in 1963
Offline NCali
Re: Pushrods......How bent is "bent"
« Reply #1 on: August 16, 2014, 09:40:45 pm »
once a push rod bends it starts to develop a weak spot at the bend. That being said I would take them out and replace the ones that wobble
Black Labs Matter
« Reply #2 on: August 17, 2014, 11:50:56 am »
roll them across a flat surface like a glass pane and check them.
