Author Topic: transmission swap  (Read 3235 times)
Offline chevy2011
transmission swap
« on: August 14, 2014, 07:32:34 am »
I have a 3 speed column shift manual transmission in a 1979 K10 custom deluxe. I want to swap in a SM465. what is required? will I have to door drive shaft work? thanks for any help.
Offline chevy2011
transmission swap
« Reply #1 on: August 14, 2014, 07:46:05 am »
left some things out on first post. I have a 1979 4x4 custom deluxe with 3 speed manual column shift transmission with a NP205 transfer case. I wanted to put in a SM465. What is required and will I have to do drive shaft work? thanks for your help
Offline thefarmboy21
Re: transmission swap
« Reply #2 on: August 14, 2014, 08:29:05 am »
I honestly didn't know they ever made a column shift 4x4.
Anyway, I'm guessing that most of your components should work for either. Main thing will be cutting the hole in the floor and putting the shifter in. If your transmission is close to the same length, you might have enough play in your driveshaft to work as long as you're using the new tranny with a 205 T-case again. Just take a straight edge front the front of the bell housing on both and measure 1. The distance to the tranny mount and 2. Distance to the tranny case.
AMSOIL DEALER # 5583011
86 Chevy K20 Custom Deluxe-Grandpa bought it new 11/20/85
77 Chevy K10 Custom Deluxe-Dad's first truck
69 Chevy C30 flatbed-Grandpa's farm truck
1950 International L-112-Grandpa bought it new, parked in 1963
Offline jhiggin
« Reply #3 on: August 14, 2014, 01:32:53 pm »
 A buddy of mine and I were gonna do the same swap on his truck and I remember reading this thread about it. Never did end up doing the swap but with the measurements we took it looked like It was pretty much be a bolt in kinda project. Hope this helps.
http://67-72chevytrucks.com/vboard/showthread.php?t=358364
