Author Topic: Rearend maintenace  (Read 3970 times)
Offline solve4x
  • Thankful Every Day!
Rearend maintenace
« on: August 16, 2014, 04:15:12 pm »
or should I say first attempt at rearend maintenance in 27 years.
87 R10 305 2wd
What type of gear oil and how much?
I assume I need to remove the backplate to drain?
The Haynes answer to all of these questions was "it depends".
Hopefully I can get the fill plug out...it looks stuck as can be.
Any other suggestions appreciated.
Scott
Scott
1987 Chevy R-10 long bed, working man's truck.
Thankful every day!
Offline NCali
Re: Rearend maintenace
« Reply #1 on: August 16, 2014, 09:43:40 pm »
I would get two quarts of 90 wt. You will use about 1 1/2 . Fill it until oil runs out of the fill hole
Black Labs Matter
« Reply #2 on: August 17, 2014, 11:42:58 am »
     If you have never opened it up before, I would, then clean it really well put on new gasket and fresh oil.  This way you can inspect the gears for wear and to see if anything does not look right.
« Reply #3 on: August 17, 2014, 11:49:39 am »
I would pull the cover and inspect everything, clean any junk out check the gears and then replace the cover pull the fill plug out of the side and fill it til it to the bottom of the fill hole.
Offline solve4x
« Reply #4 on: August 22, 2014, 11:55:18 am »
All done...gears looked great.
It took 2.5 quarts of gear oil, full to the fill hole level.
Is that a clue as to which rearend it is? .... 10 bolts, fairly round gasket.
There was no tag present.
There were several gasket choices at the parts store, so must have been several different rearends in 87.
Scott
Thankful every day!
« Reply #5 on: August 24, 2014, 11:49:28 am »
There was only 1 rearend for 87 1/2T trucks.  a 10bolt.
Offline solve4x
« Reply #6 on: August 25, 2014, 04:09:06 pm »
okay...good to know!!
Scott
Thankful every day!
