Author Topic: Getting cab off the truck  (Read 6730 times)
Offline David36605
  • Friends are family we choose
« on: August 18, 2014, 03:45:37 pm »
Hello this is my first post to this forum I own a 87 r20 , I got it for 500 complete with all bells and whistles that came with the scotsdale , I have bed and front off the truck however the cab mounts are not doing anything but spinning and I've cut one bolt I don't want to cut holes in the cab but. I'm pretty sure that I have to so I can replace the cab mounts is this true am I going about it wrong ? Any and all advice helps
Re: Getting cab off the truck
« Reply #1 on: August 18, 2014, 07:19:40 pm »
     If you can not stop them from spinning, the only option is to cut the cab and then re-weld it back up.  Welcome to the site by the way.
Offline David36605
« Reply #2 on: August 18, 2014, 07:25:09 pm »
If you don't mind how would you go about knowing were to cut in to front as it is at a angle ? The rear is easy, and thank you before I joined I used yall info for everything on the truck plan is 5.3 or 6.0 twin turbo swap with 4l80e or 6l80e trans
« Reply #3 on: August 18, 2014, 07:42:23 pm »
     There are a couple of threads on here from members who had to do the same thing.  Not sure what section they are in, or how to word it to do a search.  Normally you would have to follow from the bottom up and make an educated guess as to where to cut the hole.
     The problem is the nut that is welded inside the 2 cab metal pieces came loose.
     Another member might chime in and give more details or have the links.
Offline David36605
« Reply #4 on: August 18, 2014, 07:44:36 pm »
Will check in to them
Offline zheier
« Reply #5 on: August 28, 2014, 07:37:04 am »
drill a small hole from the underside up through the floor, then either hole saw or us a grinder and cut an access.  when we did it we didnt weld them back up and just covered the hole now have an access in case we swap again.
Offline David36605
« Reply #6 on: August 28, 2014, 07:37:46 pm »
Thanks
Offline roundhouse
« Reply #7 on: August 29, 2014, 06:11:12 am »
Got the same problem with my 71 bronco
Someone welded new metal in the floor  coveredup the body mount.
Offline David36605
« Reply #8 on: September 12, 2014, 11:39:41 am »
I finally got over it a cut into them but I left it open Co I can replace them later
