Author Topic: Fuel Pump connector  (Read 4065 times)
Offline hobbz
Fuel Pump connector
« on: August 22, 2014, 09:54:05 pm »
Is the fitting on the fuel pump that goes to the carb the same kind of fitting as on brake lines?
Can I use 3/8 brake line to make a new solid line up to the carb?
Thanks
1987 Chevy R10 Short/Step -  350/th350
Build Thread
Re: Fuel Pump connector
« Reply #1 on: August 22, 2014, 09:56:57 pm »
Yes.
Offline hobbz
« Reply #2 on: August 22, 2014, 10:02:00 pm »
thanks
Build Thread
Offline hobbz
« Reply #3 on: August 26, 2014, 08:30:22 pm »
One more question, is this the right connector to go from 8an to the hardline?
http://www.summitracing.com/parts/pfs-10450/overview/
Build Thread
« Reply #4 on: August 26, 2014, 11:18:50 pm »
What exactly are you trying to do?
Offline hobbz
« Reply #5 on: August 27, 2014, 11:51:38 am »
going to install a fuel cell behind the axle and want to run hardline from the tank to the fuel pump.
Build Thread
« Reply #6 on: August 27, 2014, 02:02:27 pm »
Factory style pump with 3/8" hose bib inlet and 5/8" inverted flare outlet?  Any return lines to deal with?
Offline hobbz
« Reply #7 on: August 27, 2014, 02:35:42 pm »
No return lines.  I have realized I am making this way to complicated.  What I will do it run rubber line from the tank to the frame rail, run hardline up the rail, then go back to rubber to connect to the pump.
On the other side of the pump, I will run hardline up to just before the carb, and run rubber to filter and then carb...
Build Thread
