Author Topic: What's the sheet metal thickness  (Read 6197 times)
Offline David36605
  • Friends are family we choose
« on: August 26, 2014, 04:36:47 pm »
Hey I have a buddy and he has a set of hole saw bits , it's rated to 1/8 of a inch
I need to drill holes for cab mounts all 4
Offline HAULIN IT
Re: What's the sheet metal thickness
« Reply #1 on: August 27, 2014, 08:05:57 pm »
David, Not exactly sure what you are wanting to do...one thing that comes to mind may be that the caged nuts are spinning inside the cab mount so you want to drill holes in the floor & work on them from the top? To give an answer to how thick...it depends on where your talking. Above the cab mount is a couple layers, but it's not an 1/8". I've never seen holesaws rated to a depth, not saying they aren't...just not something I'm familiar with. What works best is a big, slow drill & either PB blaster, WD40 or even water to cool the cutter while your going at it. heat KILLS holesaws! I wouldn't sweat the thickness much as I've cut holes in 1/2" thick plate with normal holesaws. Good Luck, Lorne
Offline David36605
« Reply #2 on: August 28, 2014, 07:34:11 pm »
Hole mine just can't or jymps
Offline David36605
« Reply #3 on: August 28, 2014, 07:37:20 pm »
It will walk I've got a pilot bit on it and it's broken 4 times , I'm getting cutoff wheel and finishing this
Offline DnStClr
« Reply #4 on: September 09, 2014, 03:10:40 pm »
Are you putting too much downward force on the drill? That's what usually causes the bit to break. Ease up- let the tool do the work.
Don
87 Chevy Silverado
Offline David36605
« Reply #5 on: September 12, 2014, 11:40:10 am »
Yes sir
