Author Topic: Removing Fenders To Access Engine  (Read 18388 times)
Offline haroldwca
Re: Removing Fenders To Access Engine
« Reply #15 on: September 05, 2014, 09:41:56 pm »
"This is just such an odd design, to me, having such inaccessible parts, or in this case most of the engine, and the spark plugs especially."
I don't understand.  Are you working on a squarebody, or have I misunderstood?  I have found the squarebody engine bays to be quite accessible, plugs and all.  If you are working on the step van in your picture, then I understand. On a squarebody, I agree that reaching everything is a bit of a chore because of height (if climbing in the engine bay is not an option), but that would be true of any pickup.  The engine creeper looks intriguing, but with a dirt floor, I see why that's not really an option, either.
By the way, if we are talking about a squarebody it is possible to remove the front fenders without removing the hood, but it does eliminate the hood springs.  You have to prop the hood with something else, which is somewhat hazardous.  At any rate, removing the fenders will be frustrating, too.  They attach at the A-pillar (top and bottom), several bolts attaching the inner fender to the outer fender, one large inner fender bolt to the lower firewall, a few bolts to the radiator support, and two bolts for the front filler panel between the grille and the bumper, which will necessitate removing the grille and headlight trim.  Any of these bolts may be rusted.  Before I would disassemble the entire front clip, I would probably just cobble together a stable stool made out of 2x4s and plywood with steps at a couple of different heights.  Good luck to you my friend, and may you get it back on the road soon!
Offline Breadvan
  • No Breadvan, '83 C10 'burban
« Reply #16 on: September 06, 2014, 08:48:13 am »
Oh, good to know about the hood springs.
The breadvan had two distinct advantages, well three if you count the fact it ran. It was a 4 cylinder diesel, and the whole hood was fibreglass and flipped up out the way, you could pop off the bump in the cab, and it was pretty easy to get at.
Mind you, I know they did put chevy V8's in there too, but I think it may have still been more accessible.
« Reply #17 on: September 06, 2014, 09:41:48 am »
73-80 hoods are attached to the fenders only 81-up could you get away with that
Offline fitz
« Reply #18 on: September 09, 2014, 09:44:11 pm »
Try stacking a few tires with rims to stand on top of. It takes the curse off of leaning  over the fender/radiator support (especially on a lifted truck).
Offline Stewart G Griffin
« Reply #19 on: September 13, 2014, 06:53:37 am »
There's a video of a blazer with a medium duty tilt frontend.  i will look for it when i get a chance.  This is definitely a project i want to do.
« Reply #20 on: September 13, 2014, 07:01:59 am »
This isn't what i was talking about, but in the meantime read this:
http://www.chuckschevytruckpages.com/tilt1.html
« Reply #21 on: September 13, 2014, 07:24:38 am »
Ok, found it:
http://www.youtube.com/watch?v=PjLgI-Gnv1c
Not only would it make getting to the engine real easy, you might lose a few pounds too.
i have seen these front ends at salvage yards from $200-$500.
