Author Topic: Vent windows, pt.2:  (Read 5215 times)
Offline Stewart G Griffin
Vent windows, pt.2:
« on: September 03, 2014, 09:02:39 pm »
Not sure what happened the original post, but anyways are there any tips for removing the vent window from the frame?
Re: Vent windows, pt.2:
« Reply #1 on: September 04, 2014, 08:33:08 pm »
      You should ask Chris what happened to the original post.
      Here is a video on U-tube.   https://www.youtube.com/watch?v=WiZOiHmcb_w
      It is for 67-72, but the process would be the same.  He does mention that fact in the video.
« Reply #2 on: September 04, 2014, 08:56:16 pm »
Are you trying to get the glass out or the frame or remove the vent assembly?
If Glass, is it broken or not?
« Reply #3 on: September 04, 2014, 09:59:25 pm »
i'm trying to get the vent window (glass only) out of the frame, not the whole assembly, but just the frame which is a compression type fit.
i got one from a "private junkyard" on tuesday.
« Reply #4 on: September 04, 2014, 10:03:55 pm »
Here's a real good video, if you get to 2:30 mins into the clip this is what i'm talking about:
https://www.youtube.com/watch?v=S8Ts2YzLInE
« Reply #5 on: September 06, 2014, 05:39:39 pm »
you will have to pry it out.
Offline DnStClr
« Reply #6 on: September 07, 2014, 03:17:15 pm »
Yes. As Chris said-  it takes some pryin---The glass is installed in a gasket, which then is put into the vent frame. It sticks pretty well... you might have to bend the curvature of the frame out a bit to remove the glass.
Don
87 Chevy Silverado
« Reply #7 on: September 07, 2014, 07:33:30 pm »
i'm worried about cracking the glass.
