Author Topic: 75 k10 Not sure if bad distributor or more?  (Read 7126 times)
Offline Hillbillydrums
« on: September 04, 2014, 06:23:38 pm »
Long story short:
Getting my truck going. Got it for sure tdc. It wont fire right. only some cylinders fire, then more, then less. Timing light on #1 doesn't flash like a strobe like it should. Off and on, then not at all, etc. Tried an old set of wires, same thing. Got a for sure good cap/coil, save thing.
Is it insufficient power to the dist. or what? Battery is good too.
Thanks
1972 C10 (Passed down since great granddad bought it new in '72)
1973 K5
1975 K10
Re: 75 k10 Not sure if bad distributor or more?
« Reply #1 on: September 04, 2014, 08:49:08 pm »
      At this point since you said everything else works.  I would pull the dist. and inspect.  If you have another one try it out.
      Have you checked the power to the dist. to see if it is constant and a good supply ?
      What type of dist. do you have ?
« Reply #2 on: September 04, 2014, 09:15:16 pm »
      At this point since you said everything else.  I would pull the dist. and inspect.  If you have another one try it out.
Have tried others. 2 gm ones that look good and one that has what looks like an acces rotor and cap. power seems to be there. Where is that wire coming from? Maybe just run a new wire just to do it
1973 K5
1975 K10
« Reply #3 on: September 04, 2014, 09:39:28 pm »
     Look in the tech section on this website.  The service manuals and wiring diagrams are all there, along with troubleshooting guides in the manuals.
Offline Don5
« Reply #4 on: September 04, 2014, 10:10:20 pm »
 Have you replaced the module in the distributor? It is located inside under the rotor button. I always check this first and even carry a spare in the glove box just in case. I have had two of these go out in my truck while driving. The motor shuts off and you coast. Not fun. I would check the wires that hook to the module as well. :) I hope this helps.
« Reply #5 on: September 04, 2014, 10:14:12 pm »
I have not, but I have tried 2 other whole assemblies and then also just interchanged parts to maybe get a good one. But.still the same outcome.
1973 K5
1975 K10
Offline Don5
« Reply #6 on: September 04, 2014, 10:26:41 pm »
When you had the number 1 cyl at TDC, did you pull the rotor cap and look at the button to see if it is aligned to the number one cyl? It sounds like it is out of time or jumped time maybe. If you did this, and everything is ok, then I would really take a long, hard, CLOSE, look at the wires. This includes the plug wires as well as all other wires. Make sure the plug wires are in correct firing order and check all wires at their connectors.
I was thinking maybe the module might have wire that is barely connected or worn. That is why I suggested the module first.
« Reply #7 on: September 05, 2014, 02:34:32 am »
how/when did it stop running?
« Reply #8 on: September 05, 2014, 09:51:22 am »
The beast was non op for 15 years. I bought it from a couple to revive it.  Ended up buying this hardly used motor with a rust bucket around it. Dropped the motor in 75. Ran. Went to hot August nights, came back, wouldn't fire. Replaced dist. (Maybe did it wrong), still no run. That problem ended up being the old mufflers were plugged with rat turds and nesting and stuff.  Im straight header at the moment. Once I unplugged it I noticed timing stuff was wrong. So here I am.
1973 K5
1975 K10
Offline thefarmboy21
« Reply #9 on: September 05, 2014, 12:34:45 pm »
My guess is you didn't put it in time the correct way. BUT let's say you did, just run a hot wire straight from battery to the distributor (ideally with a switch to kill the motor) and see if that solves the issue. If not, then it's something else.
AMSOIL DEALER # 5583011
86 Chevy K20 Custom Deluxe-Grandpa bought it new 11/20/85
77 Chevy K10 Custom Deluxe-Dad's first truck
69 Chevy C30 flatbed-Grandpa's farm truck
1950 International L-112-Grandpa bought it new, parked in 1963
« Reply #10 on: September 05, 2014, 11:00:24 pm »
how fast is the motor turning over? does it slow down on compression strokes?
