Author Topic: 700R4 engine conversion question  (Read 7742 times)
Offline Breadvan
  • No Breadvan, '83 C10 'burban
« on: September 06, 2014, 01:34:15 pm »
I apologize for really not understanding automatic transmissions in advance.
If I have a 2WD '83 C10 with a stock 700R4 in it, and I put in a diesel engine pulled from a commercial vehicle, like a tractor, it has the torque, and it has the horsepower, but they only rev up to about 2500 rpm.
So I have a torque converter, and I believe the stock stall speed is around 1200-1500rpm, so that means my engine has to go this fast for the transmission to start transmitting the power to the driveline.  Is this going to be enough? Will it change gear OK? If I'm in top gear ie. 0.70 overdrive, and I let the revs drop below 1200, does it change down automatically?
I'm looking to have a nice diesel cruiser, something where I can fill the truck with band gear, take it on the highway, and it maybe takes a little while to get it up to 60-70, but once there it's going to sit happily and chug along. The problem with the breadvan was it had two tall a gear in the rear it was like 4.5 or something, I think the C10 is like 2.73? Plugging the tire size, revs, diff ration and stock 700R4 ratios into a calculator make it look reasonable, but is that the whole picture?
RPM1st Gear2nd Gear3rd Gear4th Gear5th Gear6th Gear
5005101622
6006121927
7007142231
8008152536
9009172840
100010193145
110011213549
120012233854
130013254158
140014274463
150015294767
160017315072
170018335376
180019355781
190020376085
200021396390
210022416694
220023426999
2300244472103
2400254676108
2500264879112
« Last Edit: September 06, 2014, 01:43:17 pm by Breadvan »
Re: 700R4 engine conversion question
« Reply #1 on: September 06, 2014, 05:12:43 pm »
You need the Diesel converter in the trans you can't use one from a gas motor.
It governs you stall speed to allow you to stop in gear and the motor not die.
Offline Breadvan
« Reply #2 on: September 06, 2014, 07:45:32 pm »
So I want a lower speed stall converter? Can I have the current one rebuilt?
« Last Edit: September 06, 2014, 08:37:33 pm by Breadvan »
Offline Breadvan
« Reply #3 on: September 11, 2014, 02:29:58 pm »
For anyone reading this in the future. I talked to a pro transmission shop that specialise in the 700R4, and they said more or less, no amount of rebuilding would make the 700R4 suitable for this.
Shame, I still sorta want to get the engine, but now I have nothing to put it in. Back to working on the 350 for now.
« Reply #4 on: October 09, 2014, 11:12:04 pm »
What engine were you going to put in front of it?
Offline Breadvan
« Reply #5 on: October 11, 2014, 05:32:24 pm »
Was a JD 6329, ended up not getting it, family fun.
Offline pratherjoe
« Reply #6 on: October 13, 2014, 04:53:52 pm »
The 700R4 can be built to suit your needs.. It's a great trans as long and you fix the normal problem areas
Using Tapatalk
Offline pratherjoe
« Reply #7 on: October 13, 2014, 04:55:14 pm »
Check out precision of new Hampton, they can pretty much specialize any converter to fit your needs
Using Tapatalk
Offline Breadvan
« Reply #8 on: October 13, 2014, 05:33:23 pm »
That's odd, as I contacted the 700R4 guys whose name escapes me, the ones that pop up first on a google search, they said it wasn't suitable for something with such a low rev and high torque. Part of the reason why I didn't bother with the engine.
Offline fitz
« Reply #9 on: October 13, 2014, 06:17:02 pm »
You could always run a Turbo 400 and a Gearvendors overdrive unit.
I would love to run this combo behind a 4 BT.
Keep in mind that with a 700R4 you would have to fab up the bracket for the TV cable.
Offline roundhouse
« Reply #10 on: October 14, 2014, 06:25:31 am »
Why not just use a 6.2/6.5 diesel that was available from the factory ?
It's a bolt in deal
Offline pratherjoe
« Reply #11 on: October 14, 2014, 11:17:22 pm »
700R4's have a lower first gear, which would be great for low end torque and towing.. Teckpak also makes a universal TV cable that will make it easier  to adapt to your application
Using Tapatalk
